7-segment display blinking problem?
Results 1 to 6 of 6
    OR if you have extra i/o (let's say 8), you can even built a cheap D/A converter with resistors and an op-amp.
    serdar_ozcan's Avatar
    serdar_ozcan Guest
    Question How?
    Melanie,
    How? Please help me. I use 16f877 and how must I use hpwm command in my code?
    I assume you have a proper copy of PBP and with it came a manual? Look up the HPWM command. It comes complete with examples in the manual. Your PIC16F877 has TWO PWM channels (look at the Datasheet), HPWM will be able to activate either one or both. Once you invoke HPWM, it keeps running in background regardless what else is happening until you change or stop it. This allows you to take new ADC reading and refresh your LED Displays without the PWM interfering.
    serdar_ozcan Guest
    Question how?
    Yes, of course I have a proper copy of PBP. But, when I changed "PWM portC.2,255,100" line to "HPWM 1,255,10000", I see 3,0V. on the PortC.2 instead of 5,0V. And still I can't understand. ( crystal 20MHz.) I tried on Proteus 6.7...
    Best Regard.
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:30
  2. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 15:55
  3. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 03:12
  4. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  5. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 03:02
