@ device options
Results 1 to 9 of 9
    Feb 2005
    thnks dynamo ben.
    Peter
    Pete
    Aug 2004
    Default fuses in MPASM
    The Melanie comments on configuration fuses are dated in july 2003.
    Are there changes when using MPASM ?
    I am still receiving warnings "__CONFIG has been deprecated for 18F devices.
    Use directive CONFIG."
    Please help...
    Greetings...
    Ruben de la Pena
    Here's a previous answer from Bruce.
    http://www.picbasic.co.uk/forum/showthread.php?p=13087
    Aug 2004
    Default fuses in mpasm
    Thanks Darrell, but that response is also outdated,I think.
    I am using the MPLAB 7.3 and I still get the error messages.
    I did take the fuse from the Microchip INC file for the 18F2620:
    CONFIG OSC = HSPLL and the PBP 2.46 gives me a Syntax error.
    Any suggestion ?
    Thanks in advance...
    Ruben de la Pena
    If PBP is giving the error, then you probably need to put an @ in front of it.
    Also, comment out the __CONFIG lines in the 18f2620.inc file in the PBP folder too since they are still the old style.
    Default Sounds familiar... but it works
    http://www.picbasic.co.uk/forum/show...iguration+fuse
    Read from post 'till the end. It works.
    For now we don't have any other choice. Melabs know that and implement something for the next release.
    Thanks Microchips to reinvent the wheel daily!
  1. Watchdog Timers
    Last Post: - 27th August 2014, 19:03
  2. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 18:42
  3. help
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2005, 21:42
  4. Need once your help one please
    Last Post: - 9th February 2005, 21:33
  5. @ Device Parameters
    By Randy_Suwanee in forum General
    Last Post: - 11th August 2004, 15:40
