12f675 serial pic2pic
Results 1 to 5 of 5
    tagan's Avatar
    tagan Guest
    Default 12f675 serial pic2pic
    I am trying send serial data pic 12f675 to 16f8777 and show this value on the lcd panel but it doesn't work. here is the program code. any ideas pls.
    12f675:
    INCLUDE "MODEDEFS.BAS"
    @ DEVICE INTRC_OSC, WDT_OFF, MCLR_OFF, PWRT_ON
    define osc_4
    DEG VAR BYTE
    CMCON=7
    ANSEL=0
    TRISIO.0=0
    DEG=1
    BASLA:
    PAUSE 3000
    SEROUT2 GPIO.0,16780,["A",DEG]
    PAUSE 200
    16f877:
    define osc_4
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_RWREG PORTB
    DEFINE LCD_RWBIT 2
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEG VAR BYTE
    ADCON1=7
    TRISB=0
    TRISC=1
    LOW PORTB.2
    PAUSE 100
    LCDOUT $FE,1
    PAUSE 100
    BASLA:
    SERIN2 PORTC.0,16780,[WAIT("A"),DEG]
    PAUSE 200
    LCDOUT $FE,2,#DEG
    could be many things here. But at least, can you confirm all of the following tests
    1. Is a simple led blink work on both of your PIC
    2. Is the LCD work on your 16F877
    Another thing... is the SERIN Idle state may cause you a grief? idle what? look at the following post...
    http://www.picbasic.co.uk/forum/show...86&postcount=5
    Be sure you set the transmitter pin to the corect state before sending something.
    You DEFINE OSC is not correctly writen.. no problem anyway, it will not be considered. Chances are that the default OSC is 4. DEFINE spelling and writing is often discussed here... almost every week/month. They must be written as state in the manual, in UPPERCASE.
    DEFINE OSC 4 without any underscore.
    Also, when using 12Fs with internal osc in a serial comm, you should consider using the OSCCAL value to ensure a better Oscillator precision. Personnally i always use it, serial comm or not. it's just a simple code line after all
    SET OSCCAL_1K 1
    If you have a good device programmer, and if you're lucky, the OSCAL value is still there. To check it, just read your PIC and look at the last memory location... should different of 3fff
    what else... maybe enough to start i guess
    what about ...
    ' 12F675
    DEFINE OSCCAL_1K 1
    DEG VAR BYTE
    CMCON=7
    ANSEL=0
    TRISIO.0=0
    GPIO.0=0    ' Set corect idle state
    DEG=1
    BASLA:
        PAUSE 3000
        PAUSE 200
        goto BASLA
    You don't need to attach the R/W pin of your LCD to the PIC if you don't plan to read from. Just connect it to GND.
    tagan, How long are you waiting after poweron for the 16f877 before you powerup the 12f675? I notice that you only send the data once and end the program execution. Maybe you are not waiting long enough for the LCD display to initialize before sending the data to it. I would place a delay before the data is sent to the LCD display and make sure the 16F877 is ready to receive the data before you send it.
    tagan's Avatar
    tagan Guest
    thanks for your warning. I solve this problem change the mode 16789 to 396. yes you are right. it isnt necessarry to use portb.2 if I only write on the lcd . but it isnt my original program. it is a test. (can I use serial comminication) and get code for copy+paste from my previous program . also you are right about ossicilator. Iwill remove internal command. thanks all for I get your time and sorry for my bad english
    And oups i just notice something interesting in the 12F config file about the config fuses...
    Quote Originally Posted by M12F675.INC
    INTOSC equ 3FF80005h ; XX XXXX XXXX X101
    INTRC_OSC_CLKOUT equ 3FF80005h ; XX XXXX XXXX X101
    INTOSCIO equ 3FF80004h ; XX XXXX XXXX X100
    INTRC_OSC_NOCLKOUT equ 3FF80004h ; XX XXXX XXXX X100
    Where is the INTRC_OSC listed... oups. Might be another problem source.
    EDIT: Great to know it's working now. Don't worry about your english... it could be reaaallllly worst. I'm french and it's hard for me as well.
  1. Replies: 33
    Last Post: - 19th March 2010, 04:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  5. Serial LCD on 12F675
    By anj in forum mel PIC BASIC Pro
    Last Post: - 1st April 2004, 00:11
