LCD with T6963C controller
Results 1 to 10 of 10
    Default Re: LCD with T6963C controller
    Well, common HD44780 based displays have 5x7 font, but no one complains...
    Anyways, let them arrive and let me see, what they can do
    The pixels are smaller than on a charactor display.
    In the text mode you can get 8 lines by 30 charactors with a 240x64 display.
    Do you have a datasheet for the displays you are getting?
    Hopefully your displays have the built in negative voltage source for the contrast.
    Well as seller stated, they only need 5V for operation, no separate negative supply needed. It also has contrast adjustment pot soldered on it.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
