Bits to Word?
Results 1 to 7 of 7
Thread: Bits to Word?
    Qacer's Avatar
    Qacer Guest
    Question Bits to Word?
    Hello again all,
    Thanks very much to those who have helped me in the past! I appreciate it a lot.
    I wanted to double check here. I am reading a couple of bytes from an external device. Each bit in the byte represents a configuration code. I wanted to get bit 5 to bit 0 of one byte, also get all 7 bits of another byte, and then combine them all into a 14 bit word.
    I had the following in mind:
    databyte1 VAR byte     'This variable contains bit 5 to bit 0
    databyte2 VAR byte     'This variable contains all 7 bits of the config
    wordtoyou VAR word
    [..assuming that databyte1 and databyte2 already contain the read values..]
    databyte1 = databyte1 & %00111111
    wordtoyou.byte1 = databyte1
    wordtoyou.byte0 = databyte2
    write 0, wordtoyou.byte0
    wrte 1, wordtoyou.byte1
    Does this look okay?
    Thanks!
    Hangover, Germany
    In the past I used .lowbyte and .highbyte instead of .byte0 and .byte1.
    What does the compiler do ?
    PBP 2.50C, MCS+ 3.0.0.5, MPLAB 8, MPASM 5.14, ASIX Presto, PoScope, mE mikroBasic V7.2, PICKIT2
    Qacer's Avatar
    Qacer Guest
    Question
    It actually compiled without any problems. But now I think I have another question. If I had a byte that represents different config bits, how can I set each bit individually?
    If I had variable set as testbit VAR databyte1.0, will bit0 of databyte1 change if I set testbit to another value?
    Errr.... how would I also set multiple bits in a byte? Say, I want to set bit5 to bit0 to a certain value.
    Thanks!
    I'M BACK!!!
    Sorry to be impolite and a pest but why don't simply test it and send results to a LCD or via Serial communication to your PC to see what's happen with?
    Qacer's Avatar
    Qacer Guest
    Question
    Hi mister_e,
    :-) Sorry, I was feeling a bit lazy. Plus, I don't have the most efficient computer setup in the world. Anyway, this actually the question that I can't figure out: how would I set multiple bits in a byte simultaneously? Say, I want to set bit5 to bit0 to a certain value.
    I was hoping there was something like this:
    databyte1.[5 to 0] = %101011
    Aug 2004
    Default handling bits
    Hi:
    You can create aliases for each configuration bit. Ex:
    name1 var byte1.0
    name2 var byte1.2 etc.
    then, you can clear or set each one by
    name1 = 0, or name1 = 1
    Or you can test them:
    if name1 = 1 then do_something
    I hope this helps.
    Greetings...
    Ruben de la Pena
    Default individual bit setting/clearing
    To set bit 4 on and leave the rest unchanged:
    mybyte=mybyte | %00010000 'OR function with selected bit masked ON
    To turn bit 4 off and leave the rest unchanged:
    mybyte=mybyte & %11101111 'AND function with selected bit masked OFF
    OR you can set multiple bits on or off by either ADDING or SUBTRACTING the bit weight to/from either 0 or 255 respectively.
    ------------------Picster-----------------
    Last Post: - 14th June 2016, 08:55
  2. Minimizing code space
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 08:25
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. calculation problem
    By nicolelawsc in forum mel PIC BASIC Pro
    Last Post: - 31st March 2006, 16:23
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
