Playstation gamepad interface code?
Results 1 to 4 of 4
    dink's Avatar
    dink Guest
    Default Playstation gamepad interface code?
    Nuts and Volts magazine did an article about interfacing playstation gamepad with a Basic Stamp. The article and source code can be found http://www.parallax.com/dl/docs/cols.../col/nv101.pdf
    I am curious if anyone has similar code in picbasic? Or if anyone would have any tips on porting that to picbasic pro?
    thank you
    Jan 2006
    Istanbul
    Cool
    Here is a PBP code fully working....
    Code reads the data from PSX2 controller and displays it on LCD.
    If you use analog data to be read, make sure that your controller is good quality one. Since the pots on these controllers have very small angle to move right,left, up and down the incoming data is not quite precise.
    You will see this on LCD.
    Also, I am only adding the data reading part; but the schematic is designed for serout part also. You can refer to the schematic for PSX2 connection.
    macx75's Avatar
    macx75 Guest
    Default ps2 playstation wireless control servo
    Hi
    Has any one tried to use the ps2 wireless controller with the picbasic. ?
    Want to control servos?
    Macx
    Mar 2007
    Boston, MA USA
    Lynxmotion sells a 2.4ghz Playstation2 wireless controller for $19. http://www.lynxmotion.com/Product.as...&CategoryID=46
    I also found this article with Playstation controller information (pinouts etc.)
    http://www.gamesx.com/controldata/psxcont/psxcont.htm
    --John
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. HDD IDE ATA 2 interface problems. code wrong?
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 27th March 2005, 17:01
