Relocating PBP
Results 1 to 8 of 8
Thread: Relocating PBP
    Sep 2005
    Campbell, CA
    Default Relocating PBP
    I have been trying without success to relocate PBP so it will run in high memory.
    I iniitially thought that an @ ORG 0x1000 at the beginning of the program might do the trick, but no.
    It may be that PBP is not relocatable without major surgery, but I was wondering if anyone had successfully done this, and if so, how you did it.
    Charles Linquist
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by Charles Linquis View Post
    Kind of wondering why you would want to do that for. If it's because you're having problems compiling large programs, why don't you just use PBPW.exe that will swallow up as much memory as needed. I did a rather large burglar alarm project last year, had no choice but to use PBPW.
    Question Good Question !!!
    Hi, Charles
    For 12 to 17 series ... PbP libs. HAD to be in the 1st or Half 1st page ... could explain non relocatable code.
    but, for the 18 Series with no more paging , I didn't see anything.
    So, It certainly might be a good question for MeLabs ... ( didn't see anything in the FaQ ...)
    That could allow Much Bigger Personnal libraries ...
    Sep 2005
    Campbell, CA
    I'm very close to the point where I can (and need to) write my own bootloader. I would like to write most of the program in PBP, so I need it to reside right at the top of memory. 18F8722 only.
    Charles Linquist
    Wink the first question ... to be asked.
    Did you try a "DEFINE LOADER_USED 1" ... to see in MPLAB prog window what it does ???
    Sep 2005
    Campbell, CA
    I ALWAYS use that define, because it is necessary if you use MCLoader. It appears to move the RESET vector up by 8 locations.
    Below is a cut-and-paste from PBPP18.LIB
    ifdef LOADER_USED
    LIST
    ORG RESET_ORG + 8 ; Make sure no library code in first 4 locs
    NOLIST
    Charles Linquist
    Sep 2005
    Campbell, CA
    I might have found it - one of the first lines of PBPP18.lib is
    If I change that line, it does relocate the code. Now I just have to test to see if it still runs.
    ifndef RESET_ORG
    RESET_ORG EQU 0
    Charles Linquist
    Instead of changing the library file, you can ....
    DEFINE RESET_ORG xxxx
    In your bootloader program.
    That way it doesn't mess things up for your other programs.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 13:43
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 03:16
