Hserin
Results 1 to 4 of 4
Thread: Hserin
    Default HSERIN/OUT are not self contained instructions
    HSERIN/OUT require you to manually manage over-run errors and suchlike in the USART. This is hinted at in the paper manual but not mentioned at all in the on-line help that comes up in MicroCode Studio.
    Unless you manually fiddle with the USART registers you will have a very unreliable Tx/Rx system. I spent days farting around with this before I dumped HSERxx and went back to SEROUTx that works every time on any pin.
    New Jersey
    So my question is, am I wasting time by using the Hserin/Hserout? Are there any major benefits to using these or should I just use serin/serout?
    Jun 2005
    Wisconsin
    You're not wasting your time with HSERIN/HSEROUT. I use the onboard USART whenever possible. The reason being the onboard USART has a built in buffer.
    This means PICBasic can do other things and not miss any incoming data. In addition if you enable interrupts you serial string will be received without polling.
    The error handling isn't an issue for me because I automatically clear them as they occur with the following:
    DEFINE HSER_CLROERR 1 ' Clear all USART errors as they happen
    If I had to determine a cause I would have to say it is a setting that is missed on the new chip. Make sure all the defines and fuses are set correctly. Also make sure wiring is correct.
    Don't give up yet, its with the little amount of work.
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 11:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 05:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 15:42
