It works now. thanks. Just out of curiosity, why do you subtract 48? I forgot to mention earlier, I am using HS-2000D humidity sensor made by PRECONUSA.
the answer is located in the ASCII table in your PBP manual. Character 0 is decimal ASCII 48.
check the thread R/H Temp sensor.
Bruce used the same sensor and posted the code to show H and Temp in C and F.
I am using the same sensor and some of Bruces work in my code.
Works like a champ!!!
Joe
