"CE" mark self certification
Results 1 to 40 of 47
    Unfortunately a system of parts which are CE approved does not automatically make the System CE compliant.
    I have had a specific case where I used a CE compliant radio module in a product but still had to have the product approved to the R&TTE directive. On a brighter note (?) the use of CE approved parts DOES reduce the overall system approval (ie using a CE approved Power Supply will dramatically reduce, or in some cases, remove the need for the assessment to the Low Voltage Directive
    malc-c's Avatar
    malc-c Guest
    This does really get confusing..
    So assuming I gathered all the data and compliance sheets for the components and parts used, which should mean that the parts to be sold would already be CE marked or compliant, it still means the final unit has to be tested? - Bummer !!!
    I'm awaiting a call from the business section of our local trading standards office (well they are apparently responsible for policing the CE marking) to hear their view point. I'll let you know the outcome
    malc-c's Avatar
    malc-c Guest
    Default Interesting
    Well I've received a call from a very helpful lady at my local trading standards office. Cutting a long story short, I would only need to comply for the directives under the CE declaration if I was a business. If the sales are private, and in effect an extension of a hobby (which it is) then it doesn't need to be CE marked and really only needs to comply with "basic" standards. Here is a quote from her e-mail
    The Consumer Protection Act 1987 defines a supply of goods by a person in the "course of a business" in relation to the offenses of breaching safety regulations, therefore, it could be argued that the action you propose, is not done as a business but more of a "hobby". Therefore, you would be exempt from the legislative requirements. Please note though that this an interpretation of the law and what is deemed as a 'hobby' or in course of a business is ultimately the decision of a Judge.
    If you produce the product following the legal requirements or a relevant British or European Harmonised Standard (BS/EN) such as any plug supplied should comply and be labelled as such with BS1363 or complying with the essential requirements of the electrical equipment safety regulations, then it could be argued that you have taken steps of due diligence to ensure the product is safe, but also been mindful of potentially foreseeable risk hazards and design them out.
    There are still gray areas such as what point does a hobby become a business, and obviously I could still find myself in trouble should someone pursue a civil case against me, but that could be the case if I was running this as a business and selling 1000's a year or an individual selling 10 !
    I still want to undertake a lot more testing of my own, but I feel happy to know that I can still recover some of my costs by building and selling the remaining 5 units without breaking the law.
    Ginrummy's Avatar
    Ginrummy Guest
    Default Re: "CE" mark self certification
    Just hopped by...
    I have spoken with both my local TS office AND two companies that do LVD and EMC testing, reading the need for CE.
    My product would be made up of already-marked CE items (only a few), and while TS say the WHOLE package must be CE marked again, one of the LVD/EMC companies said it was not as if I was a manufacturer, while the other sided with TS.
    I'm minded to think very strongly that if you bring together two or more components, and I'm talking electrical components here, and even if they are CE marked themselves, then you DO, in fact, have to certify the whole lot.
    Cheers
  1. Display Quotation mark
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2009, 07:22
  2. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 13:47
  3. MPLAB V8.00 PBP2.50a questions mark
    By flash70 in forum mel PIC BASIC Pro
    Last Post: - 25th March 2008, 21:03
