Reading EEPROM data?
Results 1 to 3 of 3
    Qacer's Avatar
    Qacer Guest
    Question Reading EEPROM data?
    Hi again all,
    I have the following code:
    I2CWRITE I2CDAT, I2CLCK,addr,[fmwrt1,fmwrt2,fmwrt3,fmwrt4,fmwrt5], NOGO
    Pause 200
    I2CREAD I2CDAT, I2CLCK,addr,[fmred1,fmred2,fmred3,fmred4], NOGO
    WRITE 0,fmred1
    WRITE 1,fmred2
    WRITE 2,fmred3
    WRITE 3,fmred4
    I am trying to read the EEPROM data values, but I can't seem to get it to work. I think it maybe the fact that when I plug the chip back into the programmer, the code is executed again and (maybe?) overwriting the data in the same EEPROM address.
    Any tips?
    My main objective is to just read the current values from an I2C device and store those values in the EEPROM so I can view it using MPLAB.
    Thanks!
    Maybe you could use another EEPROM location as a Flag, so that it only runs once.
    READ 127,temp
    IF (temp <> 1) then
        Pause 200
        WRITE 0,fmred1
        WRITE 1,fmred2
        WRITE 2,fmred3
        WRITE 3,fmred4
        temp = 1
        WRITE 127, temp
    P.S. You might need a Big pause at the beginning, to allow time to remove the power after programming.
    Qacer's Avatar
    Qacer Guest
    Talking
    Ahh, thanks, Darrel! :-) This should work.
  1. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
