PIC to PIC communications
Results 1 to 3 of 3
    Nov 2004
    Calabasas, CA
    Default PIC to PIC communications
    I cannot transfer a variable from one PIC to another as:
    master: SEROUT B.7,N2400,[w2]
    slave: SERIN B.0,N2400,[w2]
    It appears that the slave does not wait for any serin (the pic's run in 2 different programs/circuits). How to implement a "wait til receive a serial connection"?
    Would it be something like:
    SERIN B.0,N2400,100,[w2]
    to wait for 100ms?
    James
    Feb 2005
    Kolkata-India
    Default Which PIC are you using ?
    Why not use the serin2 / serout2 with flow control. That should solve your problem. If you are using the Hardware USART then interrupt in another option.
    Sougata
    Nov 2004
    Calabasas, CA
    Using (2) PIC16C716's simply w2=100
    I was under the impression that the slave would wait (forever in above example) until data (w2) is recieved?
    I found this in some thread:
    master:
    SEROUT2 PortB.7,N2400,100,Main,[Wait "A",w2]
    slave:
    SERIN2 PortB.0,N2400,100,Main,[Wait "A",w2]
    Does this wait 100ms and if no transfer go to Main subr?
    Will this transfer var contents of w2? There is something about Wait "A" I've seen. Can you give example?
    James
  1. Replies: 24
    Last Post: - 2nd October 2017, 11:35
  2. PIC Basic Pro <-> HP-IL communications
    By swr999 in forum Serial
    Last Post: - 6th March 2006, 18:30
  3. PIC Basic Pro <-> HP-IL communications
    By swr999 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2006, 18:22
  4. PIC to PIC communications
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 04:46
  5. PC / PIC communications?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 17:55
