Troubled by LCD
Results 1 to 17 of 17
Thread: Troubled by LCD
    Default All tried
    Hi, I have considered most of your tips, I am using a POT for the contrast and a resistor for the BackLight, My new discovery is that although i bought yet another LCD 4x20 the same results appear, my guess is that the datadelay and command delay are not correct, do you have any idea of what the correct values would be for this LCD?, i am pretty sure that everything else is correct because i made a simple HELLO WORLD test and the uC keeps turning off, by the way i am using a strong LM338 (5 AMPS regulator ) so i think the Power is ok.
    I am going for the delays, any suggestion is appreciated as i dont kwon what this delays mean
    Feb 2005
    Kolkata-India
    Default LCD delays
    The LCD controller takes a finite time to excute a command (the $FE ones) and take in the DATA (character to be displayed). Normally PBP does not poll the busy flag on the LCD to know if the LCD has successfully executed a command (or taken a data) and ready for the next. So the LCD defines assures that data and commands are not passed to the LCD too fast. If the LCD is slower it will definately loose character (s). So the delays assure that the speed of your PBP + PIC is slower than what the LCD can take.
    However for your particular problem it is necessary to know what is causing the reset. So I suggested to check the STACK and POR registers. Please post your entire code. Sometimes typos are hard to find (yourself).
    If possible post the schematic too.
    Sougata
    Default Solved, thanks for the help!
    OK, the problem was with the power after all, i used a decoupling Capacitor to the uC and all my problems where gone!, i really cant believe yet as i had such a huge regulator for the application.
    MENTAL NOTE : Never forget that 103 Capacitor between Vcc and Vdd ever again!
    Jun 2005
    Wisconsin
    That’s what I thought. I had this problem some time back when I moved a project to another PIC. Bruce explained to me the reason why it occurs with some PICs and not others, I just don't remember.
    Long story short, you always need that cap.
    These are sometimes called "bypass" or "decoupling caps". They act as a
    local voltage source during high frequency noise spikes. Without them, the
    PIC can reset, lock up, or just act plain crazy. You might even think there's
    a problem with your firmware when all you did was forget that silly cap.
    Think of them as tiny little fast-acting batteries that keep the PIC Vcc and
    ground pins stable during fast noise spikes.
    They charge up to your power supply voltage, then quickly discharge during
    brief switching current spikes to maintain voltage levels.
    It's a good idea to add bypass or decoupling caps near all IC's in your circuit.
    I normally include one at every Vcc/gnd connection point.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    smokeysteve's Avatar
    smokeysteve Guest
    If anyone is looking for the datasheet for the LCD marked QY-2004A, it is sold by Sure Electronics under the code DE-LM005.
    The datasheet is currently available from:
    http://www.sure-electronics.net/mcu,...y/DE-LM005.pdf
    Everything Bruce said here is spot on target, I would add, they act as very fast-acting short circuits to noise spikes in the upward direction too. . .smooth out the highs and the lows . . Great little gadgets . . .
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
