For ... Next
Results 1 to 4 of 4
Thread: For ... Next
    micro's Avatar
    micro Guest
    Default For ... Next
    i want to print numbres from 0 to 10 and display it on LCD as below
    I var byte
    main
    i=0
    for i=0 to 10
    serout 2,2,[#I]
    next I
    but i note the first number will be 1 not 0, i tried to change idea as below
    I var byte
    Z var byte
    main
    z=0
    for i=0 to 10
    serout 2,2,[#z]
    z=z+1
    next I
    but the problem still exist
    any idea to solve that ?
    Jun 2005
    Wisconsin
    Try this:
    i var byte
    main
    for i=0 to 10
    serout 2,2,[DEC i]
    next i
    Jan 2006
    Istanbul
    Cool
    Also try this.
    i var byte
    i=0
    While i<11
    serout 2,2,[#i]
    i=i+1
    wend
    That is gonna be so fast.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    micro,
    Your first command to print the 0 might be missed if you are not “idling high”.
    Add the following line
    PORTB.2 =1
    somewhere before your first SEROUT statement and all should be well with your original code. This line will cause pin 2 to idle high, which is required for T9600. Let us know how it turns out.
    Oh, you also should add a ":" to your first main so that it looks like main:
    Good Luck,
    Paul Borgmeier
    USA
