Prob osc with PIC16f876 20 sp
Results 1 to 5 of 5
    Are you setting oscillator selection bits in config word for HS?
    A 20MHz crystal requires a higher drive level output on osc2. Make sure you
    set config word for HS instead of XT.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    kris's Avatar
    kris Guest
    Default Thanks melanie
    I changed my caps by 10 pF and my pic work correctly.
    I have another question, How you choose yours caps ?
    thank you
    If I told you Kris, everybody would start doing it...
    Aw, all right, just between you and me - I read the PIC Datasheet!
  1. INT2 anomaly in DT_INTS-18??
    Last Post: - 17th February 2010, 21:07
  2. Setting up a 12F683 to run at 20 Mhz
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 03:46
  3. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 04:19
  4. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  5. reducing the ADC time, pic877a with 20 MHZ osc
    By toalan in forum Off Topic
    Last Post: - 23rd February 2005, 18:58
