Prob osc with PIC16f876 20 sp
Results 1 to 5 of 5
    kris's Avatar
    kris Guest
    Unhappy Prob osc with PIC16f876 20 sp
    Hello,
    I use a pic 16f876 20sp with oscillator 20 mhz and 2 capacitors 33 pf and
    my prog is:
    Define osc 20
    loop: PORTB.0=0
    Pause 500
    PORTB.0=1
    Pause 500
    Goto loop
    Why my prog doesn't work? I don't understand because the same prog with pic 16f876 4sp with oscillator 4 mhz and 2 capacitors 33 pf works ( lineless
    Define osc 20)
    If you know with probleme please help me!
    Thank you Kris
    33pF seems high at 20MHz... remove the Caps and see if it works then.
    Are you setting oscillator selection bits in config word for HS?
    A 20MHz crystal requires a higher drive level output on osc2. Make sure you
    set config word for HS instead of XT.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    kris's Avatar
    kris Guest
    Default Thanks melanie
    I changed my caps by 10 pF and my pic work correctly.
    I have another question, How you choose yours caps ?
    thank you
    If I told you Kris, everybody would start doing it...
    Aw, all right, just between you and me - I read the PIC Datasheet!
  1. INT2 anomaly in DT_INTS-18??
    Last Post: - 17th February 2010, 20:07
  2. Setting up a 12F683 to run at 20 Mhz
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 02:46
  3. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 03:19
  4. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 01:31
  5. reducing the ADC time, pic877a with 20 MHZ osc
    By toalan in forum Off Topic
    Last Post: - 23rd February 2005, 17:58
