Hello All....
It's been a while since I have done any coding, and I'm stumped as to the problem, I'm sure it's a math problem, or an array problem.
The following code is where I'm having the problem:
@ DEVICE pic16F648A, HS_OSC
'@ DEVICE pic16F648A, INTRC_OSC_NOCLKOUT
' System Clock Options
@ DEVICE pic16F648A, WDT_ON
' Watchdog Timer
@ DEVICE pic16F648A, PWRT_ON
' Power-On Timer
@ DEVICE pic16F648A, MCLR_OFF
' Master Clear Options (Internal)
@ DEVICE pic16F648A, BOD_ON
' Brown-Out Detect
'@ DEVICE pic16F648A, LVP_ON
' Low-Voltage Programming
@ DEVICE pic16F648A, CPD_OFF
' Data Memory Code Protect
@ DEVICE pic16F648A, PROTECT_OFF
' Program Code Protection
DEFINE OSC 20
DEFINE LCD_DREG PORTA
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 3
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
DEFINE DEBUG_REG PORTB
DEFINE DEBUG_BIT 2
DEFINE DEBUG_BAUD 9600
DEFINE DEBUG_MODE 1
DEFINE DEBUGIN_REG PORTB
DEFINE DEBUGIN_BIT 1
DEFINE DEBUGIN_BAUD 9600
DEFINE DEBUGIN_MODE 1
CMCON = 7 'set PORT A to Digital
TRISA = %00000000
TRISB = %00000000
clear
Pause 2000 'Wait for LCD to startup
Lcdout $FE,1 'Clear Display
high PORTB.0 'Turn LCD backlight OFF
myVar VAR byte[10] 'Array for inbound serial data
X VAR BYTE 'Holds "I" start position
FL VAR word
ID VAR word
Begin:
debugin [STR myVar\10] 'I010010101001010 Data string
FOR X = 0 TO 9
IF myVar[X] = "I" THEN Sort ' Look for "I"
NEXT X
GOTO BEGIN
Sort:
low PORTB.0 'Turn LCD backlight ON
lcdout $FE,1,"String=",myvar[2]
lcdout $FE,$C0,myvar[3],myvar[4],myvar[5],myvar[6],myvar[7],myvar[8],myvar[9]
'The above line outputs the correct string
Pause 2000
FL = 0
fl = myVar[5]
fl = FL + (myVar[4]*10)
fl = fl + (myVar[3]*100)
FL = fl + (myVar[2]*1000)
lcdout $FE,1,"FL=",dec4 fl 'Output to LCD
'The above line output is wrong, it should be 0100
ID = 0
ID = myVar[9]
ID = ID + myVar[8]*10
ID = ID + myVar[7]*100
ID = ID + myVar[6]*1000
Lcdout $FE,$C0,"ID=",dec4 ID 'Output to LCD
'The above line output is wrong, it should be 1010
pause 5000
High PORTB.0 'Turn LCD backlight ON
Lcdout $FE,1 'Clear the LCD
GOTO Begin
Any help would be muchly appreciated.
Thanks in advance.
