16F676 Interupt
Results 1 to 3 of 3
Thread: 16F676 Interupt
    Fayetteville Arkansas
    Default 16F676 Interupt
    I'm switching from a 12F629 to a 16F676 to get more pins and trying to work out the differences in the pics. The following is supposed to use a falling edge Port Change Interupt on Pin 2. The program Blinks an LED at power up and is supposed to blink it 5 times at interupt. It blinks at power up but does not interupt. I had all of it worked out for the 629 and am sure there is something small I'm missing, but I can't seem to find it. Any help would be appriciated.
    @ DEVICE PIC16F676,INTRC_OSC_NOCLKOUT,WDT_ON,PWRT_OFF,BOD_O FF,PROTECT_OFF,CPD_OFF,MCLR_OFF
    ANSEL = 0 ' DISABLE THE ANALOG INPUT
    CMCON = 7 ' DISABLE COMPARATOR ON PORTA
    VRCON = 0 ' A/D Voltage reference disabled
    TRISA = %00111110
    WPUA = %00110110
    SYMBOL TRIG = PORTA.5
    SYMBOL LED = PORTA.0
    I VAR WORD
    INTCON = %10000000
    IOCA = %00100000
    OPTION_REG = %00001000
    OUTPUT PORTA.0
    LOW LED
    PAUSE 1000
    HIGH LED
    GOTO BASE
    MYINT:
    INTCON = %10000000
    ILOOP:
    I = I + 1
    IF I = 5 THEN
    GOTO BASE
    GOTO ILOOP
    LOW LED
    PAUSE 1000
    IF TRIG = 0 THEN
    GOTO ILOOP
    BASE:
    I = 0
    ON INTERRUPT GOTO MYINT:
    INTCON = %10001000
    LOOP:
    SLEEP 240
    GOTO LOOP
    New England
    Hi Butch,
    Check out this bit...
    ILOOP:
    I = I + 1
    IF I = 5 THEN
    GOTO BASE
    GOTO ILOOP
    When interrupted, that will just increment 'I', jump back to 'ILOOP, then go back to 'BASE' when 'I'=5, never blinking the LED.
    BTW - the 'MYINT' should terminate with a 'RESUME' - don't know what will happen the way it is in your code.
    Arch
    Thank you Arch. I looked at that so many times its nuts and never saw it. Figured another set of eyes would pick something up easily. Works like a charm now!
  1. Replies: 4
    Last Post: - 17th December 2009, 01:29
  2. Help! My 'interupt', erhm ...only interupts the one time?!!!
    Last Post: - 2nd November 2009, 13:49
  3. on interupt with pic 16F619
    Last Post: - 29th March 2008, 18:39
  4. 16F676 Interupt on Change pin determination
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 5th May 2006, 18:04
  5. interupt & Sleep Problem - HELP!!
    By Santana in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2004, 11:39
