@sleep
Results 1 to 9 of 9
Thread: @sleep
    jheissjr's Avatar
    jheissjr Guest
    Default @sleep
    Using the below example I found in the old forum, I am having trouble with the @SLEEP command. The trouble I am having is that the PIC is waking up from sleep without the RB0/INT interrupt being triggerd. If I just let the PIC sit with no interrupt trigger source, it still flashes the LED when it should just be sleeping. Nothing is connected to the PIC except an indicator led on PortA and a wire to ground RB0/INT which triggers the interrupt. Any suggestions
    jheissjr's Avatar
    jheissjr Guest
    Forgot to mention, the code does wake up it from sleep as it is supposed to. It just doesn't stay asleep when it hits the @ SLEEP line.
    '16F628A
    DEFINE OSC 10
    TRISB = %000000001
    TRISA.2 = %0 'Ouput Pin for Turning On/Off LED
    CMCON = 7
    OPTION_REG.7=0 ' 0=Enable PORTB Pull Ups
    OPTION_REG.6=0 ' 1=RB0 Rising-Edge Trigger, 0=Falling-Edge Trigger
    @CONFIG.2 = 0 ' 0=Watch Dog Off
    @CONFIG.6 = 0 ' 0=Brown Out Off
    @CONFIG.4 = 0 ' Set for High Speed Crystal
    @CONFIG.1 = 1 ' Set for High Speed Crystal
    @CONFIG.0 = 0 ' Set for High Speed Crystal
    top:
    INTCON=%00011000 ' Interrupt Control Register
    ' 7=0 - GIE - Global Interrupt Enable
    ' 6=0 - PEIE - Peripheral Interrupt Enable
    ' 5=0 - TOIE - TMR0 Overflow Interrupt Enable
    ' 4=1 - INTE - RB0/INT Enable
    ' 3=1 - RBIE - PORTB change interrupt Enable
    ' 2=0 - TOIF - TMR0 Overflow Flag
    ' 1-0 - INTF - RB0/Ext Interrupt Flag
    ' 0=0 - RBIF - PORTB Interrupt Flag
    @ SLEEP
    Pause 100
    PORTA.2 = 1 'Turn LED On for 1 second
    PORTA.2 = 0 'Turn LED off before going back to sleep
    goto top
    Feb 2005
    Kolkata-India
    Default It may be the watchdog timer
    PBP uses the watchdog timer for its own sleep function. Even if you are running your asm sleep instruction the wdt wakes the PIC. There is a define that prevents PBP compiler from automatically inserting the clearwdt instruction. Combine it with the config registers to turn off the watchdog timer. I have never used it. Please check.
    Sougata
    If you're using the Assembler @ SLEEP, the WDT needs to be Disabled (OFF).
    jheissjr's Avatar
    jheissjr Guest
    Hi Melanie,
    I agree that the Watch Dog needs to be disabled. I used this line which I thought should do it:
    Also tried this too
    @ CONFIG.2 = 0 ' 0=Watch Dog Off
    Maybe the order or location which I have the line is not correct? Or if I try disabling the watch dog using either of these two lines instead of @CONFIG.2=0, I get an 'Illegal Opcode (WDT_OFF)' error from MPASM.
    @DEVICE WDT_OFF => Illegal Opcode (WDT_OFF)
    @ DEVICE WDT_OFF => Illegal Opcode (WDT_OFF)
    WDT is usually controlled from the Config Fuse definitions...
    Although Microchip have recently started tinkering with the CONFIG statement, so look in MPLABS HELP file for the latest syntax. Whn I've time I'll update that thread... or perhaps someone else might want to tag the latest MPASM amendments onto it...
    jheissjr's Avatar
    jheissjr Guest
    In the datasheet it says "If the device is in Sleep mode, a WDT time out causes the device to wake up and continue with normal operation."
    The next line says "The Watch Dog can be permanently disabled by programming the configuration bit WDTE as clear." That is just what I have in my code (CONFIG.2 = 0) yet the PIC is still resetting itself.
    Have you checked that when you burn your PIC, the WDT is set to OFF in your programming software?
    jheissjr's Avatar
    jheissjr Guest
    This is why I love the forum. That was the problem! Just incase anyone is using ICPROG and encounters this same problem, you have to uncheck the WDT check box. Thank you Melanie!
  1. 12c508 @sleep command?
    By rtsandiego in forum mel PIC BASIC Pro
    Last Post: - 14th January 2004, 07:59
