Using the below example I found in the old forum, I am having trouble with the @SLEEP command. The trouble I am having is that the PIC is waking up from sleep without the RB0/INT interrupt being triggerd. If I just let the PIC sit with no interrupt trigger source, it still flashes the LED when it should just be sleeping. Nothing is connected to the PIC except an indicator led on PortA and a wire to ground RB0/INT which triggers the interrupt. Any suggestions![]()
