PIR1.0 stays ever 1 ?!
Results 1 to 8 of 8
    mischl,
    I've found that you can rely 100% on the power-on states shown in the datasheets. So, there's no way that it's just starting by itself without something in the program doing it.
    Check all those "Magic Numbers" that were probably Cut&Paste at the top of the program. Make sure you aren't setting the wrong bit's somewhere.
    Of course, if we had the top of the program, we could look too.
    And, oh yeah. Third time for this link today...
    instruction execution time
    http://www.picbasic.co.uk/forum/showthread.php?t=365
    dear darrel
    thanks a lot for your message. alone the commitment "it must work" helps me a lot. i tested now a bit and it works fine! unfortunalety i don't know why... it seems that i had somewhere a "magic number" which i've deleted once ....
    also thanks for the instruction execution time link, i know them ;-)
    probaply i was not really clear : my problem is not "how many cycles i need" because i'm knowing that, my problem is "how long is acycle in realtime"?
    menas the instruction time on a 20mhz is 200ns. if i repeat them 5 million times, i need a second. but when the instruction time is only 199ns (only a shift of 0.5%) i get not 1.000s.
    so when i make a long time measurement for my ten minute timer, i should see if there is a small shift. that's what i need to check. so the idea was to send out a serial command at start sequence and send anotehr at end sequence. in theorie, this are xyz cycles equal to 10 minutes at the microcontroller. but my tests are around 50ms too short. ok, not the world. but when i want to build a timer for videoframes (25 frames a second) it's one frame away...
    so in fact that not ever get the same result, i first of all search for a exact method to measure before i want to calibrate. does anyone know how this is done at the olympic timer example?
    thanks a lot
    i know it's only microcontrolling, but i like it!
    The problem may not be in the measurement technique.
    More than likely, it's due to two things. The first being ON INTERRUPT. Since it waits until the current Line of code has finished before it branches to the interrupt handler, you never know when the interrupt will actually be handled. If a Long Running statement like SEROUT is in progress when an interrupt occurs, it may be several milliseconds before it gets to the handler.
    The second problem comes from just Loading the required "Count" into the timer on each interrupt. This causes it to lose however many cycles it took to get to the handler.
    If you ADD the "Count" to the current timer value, it can compensate for the lost time. The way it works is ... Once the timer overflows from 65535 and creates an interrupt, the timers value is now 0, and the timer is still running. Once it finally gets to the interrupt handler, the timer value shows exactly how long it took to get there. So now, if you add "Count" to the timers value (plus the time it actually took to add it), you'll have accounted for everything, and Time will count normaly.
    Using the ADD technique with ON INTERRUPT will definately help. But, I would suggest moving to ASM interrupts if you need to keep Long Term time accuracy, or Short term precision.
    HTH,
    &nbsp; Darrel
    P.S. Since you mentioned it. Melanie's Olympic Timer shows one way to do the ADD thing. See the SetTimer routine.
    Last edited by Darrel Taylor; - 9th March 2006 at 00:16. Reason: Olympic sized Omission
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
