PIR1.0 stays ever 1 ?!
Results 1 to 8 of 8
    Default PIR1.0 stays ever 1 ?!
    hello all
    i work with a timer1 on a 16f876 at 20 mhz. i used such a snippet some other times succesful. on this other cases i've ever immedeatly start timer1. probaply so i never found this problem...
    the problem is that i fall immeadetly to the interupt handler.
    i have a longer while-wend in the pre loop to wait for some user inputs. timer1 should not start until end of pre loop.
    i've tested also with the ICD, where i saw that PIR1.0 is set to 1 on boot up and also after reset in interrupt handler it goes back very (too) fast. i've also try with PIR1.0 = 0 at the begin of the code. no success
    probaply i search on the wrong end, but i think from there is coming up the problem.
    thanks for any hint. cheers, mischl
     				... init
    '-- PRE LOOP ----------------------------------------------------
                  while not ((buto = 3) and (dezi = 1))
                    .... stays longer here
                  wend
                  T1CON = %00000000           ' set timer1 prescaler as 1:1. stop timer1
                  PIR1.0 = 0                  ' clear timer1 overflow flag
                  PIE1 = %00000001            ' enable interrupt on timer1 overflow
                  INTCON.6 = 1                ' enable peripheral (unmasked) interrupts
                  INTCON.7 = 1                ' enable global interrupts
                  gosub SetTimer              ' start timer1
                  on interrupt goto handler   ' handling interrupt
    '-- MAIN LOOP ---------------------------------------------------
                  ... do something
                  GOTO main
    '-- INTERRUPT SERVICE ROUTINE ----------------------------------
                  disable interrupt           ' disable interrupts in handler
    handler:
                  gosub SetTimer
                  fram = fram + 1
                  if fram > 24 then
                    fram = 0
                    seco = seco + 1
                    if seco > 59 then
                      seco = 0
                      minu = minu + 1
                      if minu > 39 then
                        minu = 0
                        seco = 0
                        fram = 0
                  fcnt = fcnt + 1             ' inc frame counter
                  frsh = 1                    ' set refresh lcd flag
                  resume main
    SetTimer:
                  T1CON.0 = 0                 ' stop timer1
                  TMR1H = $63                 ' load with 25536 = 65536 - 40000
                  TMR1L = $c0
                  T1CON.0 = 1                 ' start timer1
                  enable interrupt            ' enable interrupts after handler
    '-- SUB --------------------------------------------------------
    i know it's only microcontrolling, but i like it!
    mischl,
    @ 20 mhz, loading TMR1 with $63C0 will result in an interrupt frequency of 125 hz.   The program appears to be looking for 25 hz, which is what it would be at 4 mhz.
    But the bigger problem is ... With "resume main", you are restarting the loop after every interrupt. If there's anything substantial going on in the main loop, then it may not even make it through before restarting again.
    Just use RESUME without the main.
    Default start & stop timer1 seems not work...
    dear darrel
    thanks for your reply
    you are right about preloading timer1, i've changed two steps before from 4mhz to 20 mhz ;-)
    RESUME MAIN would be fine theoretical when the interrupt routine is started only when pointer is in main loop. now it is a problem because even when the ISR is executed, the pointer jumps into main loop after.
    i've changed the "resume main" to resume" only, and it work better....
    but my basic problem is still here, timer1 overflows to early in the programm code (in the while-when of the pre loop). but my idea is to start timer1 not until end of pre loop. why does this appear? in my opinion only T1CON.0 = 1 starts the timer1, isn't it?
    i've now solved the problem with a flag :
    - clear it at begin of init
    - execute ISR only when it is 1, else resume
    - set flag = 1 on end of init section
    so, fine would be if i could reach that with timer1
    thanks for any hints again. cheers
    Default calibration of a timer
    hello all
    to the entry above
    no one an idea why timer1 runs without a start command? did i done something obviously incorrect? thanks for a feedback
    the application is like a stop watch. i will control a loop of about ten minutes and this should be very exact. means about 20ms in relation of 10 minutes. to verify that in real time i need a good idea to control them in real world. for that i send a short serial command after start and one more after stoping the timing sequence. i look at the serial terminal on the pc for the timestamp (resolution 1/100s) when the messages arrived. unfortunalety the difference is not on each run the same.. i think it is a problem of the buffer at the pc end. pic is stable i think.
    anyone a good idea how i could verify and measure them also?
    thanks a lot
    mischl,
    I've found that you can rely 100% on the power-on states shown in the datasheets. So, there's no way that it's just starting by itself without something in the program doing it.
    Check all those "Magic Numbers" that were probably Cut&Paste at the top of the program. Make sure you aren't setting the wrong bit's somewhere.
    Of course, if we had the top of the program, we could look too.
    And, oh yeah. Third time for this link today...
    instruction execution time
    http://www.picbasic.co.uk/forum/showthread.php?t=365
    dear darrel
    thanks a lot for your message. alone the commitment "it must work" helps me a lot. i tested now a bit and it works fine! unfortunalety i don't know why... it seems that i had somewhere a "magic number" which i've deleted once ....
    also thanks for the instruction execution time link, i know them ;-)
    probaply i was not really clear : my problem is not "how many cycles i need" because i'm knowing that, my problem is "how long is acycle in realtime"?
    menas the instruction time on a 20mhz is 200ns. if i repeat them 5 million times, i need a second. but when the instruction time is only 199ns (only a shift of 0.5%) i get not 1.000s.
    so when i make a long time measurement for my ten minute timer, i should see if there is a small shift. that's what i need to check. so the idea was to send out a serial command at start sequence and send anotehr at end sequence. in theorie, this are xyz cycles equal to 10 minutes at the microcontroller. but my tests are around 50ms too short. ok, not the world. but when i want to build a timer for videoframes (25 frames a second) it's one frame away...
    so in fact that not ever get the same result, i first of all search for a exact method to measure before i want to calibrate. does anyone know how this is done at the olympic timer example?
    thanks a lot
    Default works much better
    hello darrel
    thanks for your hint. sorry my late reply - had some days off :-)
    with the add command it works much more better, good tip. thanks!
    i searched a while for the asm interrupt and found one older thread from you. what i don't found is an information why asm interrupt routines are much more accurate then pbp statements.... a short info would be very nice.
    thanks for all again
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
