Byte Alignment
Results 1 to 8 of 8
Thread: Byte Alignment
    G4LCH's Avatar
    G4LCH Guest
    Question Byte Alignment
    This may seem like a strange question but its not ;-)
    Is there any memory / speed advantage with byte aligning the var defs
    eg
    MyArray Var Word(10)
    MyWord Var Word
    MyByte Var Byte
    MyBit Var Bit
    As opposed to
    MyByte Var Byte
    MyBit Var Bit
    MyWord Var Word
    In my testing I can see that there is a difference in the memory footprint
    and one would guess an increase in speed because at a low level the processor does not need to work so hard??
    In other systems that can make quite large speed / memory savings and I just wanted to check that I am not bonkers.
    Mark
    This shouldn't make any difference.
        MyWord Var Word
        MyByte Var Byte
        MyBit Var Bit
    ' Creates;
        _MyArray   EQU RAM_START + 018h
        _MyWord    EQU RAM_START + 02Ch
        _MyByte    EQU RAM_START + 02Eh
        PB01       EQU RAM_START + 02Fh
        MyByte Var Byte
        MyBit Var Bit
        MyWord Var Word
    '  Creates
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Awwwww! Bruce beats me again.
    And he's right. Doesn't make much difference. PBP catagorizes the variables according to type, and then sorts them alphabetically within each type.
    The "order" depends on whether you are using a 14-bit or 16-bit core.
    For 14-bit cores the order is ...
    1 - WORD arrays
    2 - BYTE arrays
    3 - WORD's
    4 - BIT array's
    5 - BYTE's
    6 - BIT's
    For 16-bit cores the order is ...
    1 - Bit Arrays
    2 - Bit's
    3 - WORD's
    4 - BYTE's
    5 - BYTE Arrays
    6 - WORD arrays
    A good question might be, Why the difference?
    Here's an example of the differences using these variables
    Cbyte      VAR BYTE
    BBYTEArray VAR BYTE(10)
    BwordArray VAR WORD(10)
    AWORD      VAR WORD
    BWORD      VAR WORD
    ABYTEArray VAR BYTE(10)
    AbitArray  VAR bit(10)
    DWORD      VAR WORD
    ABYTE      VAR BYTE
    BBYTE      VAR BYTE
    AWORDArray VAR WORD(10)
    CBit       VAR Bit
    BbitArray  VAR bit(10)
    Compiled for a 16F877 you get this...
      _AWORDArray    EQU     RAM_START + 018h
      _BwordArray    EQU     RAM_START + 02Ch
      _ABYTEArray    EQU     RAM_START + 040h
      _BBYTEArray    EQU     RAM_START + 04Ah
      _AWORD         EQU     RAM_START + 054h
      _BWORD         EQU     RAM_START + 056h
      _DWORD         EQU     RAM_START + 058h
      PBA01          EQU     RAM_START + 05Ah
      PBA02          EQU     RAM_START + 05Ch
      _ABYTE         EQU     RAM_START + 05Eh
      _BBYTE         EQU     RAM_START + 05Fh
      _Cbyte         EQU     RAM_START + 080h
      PB01           EQU     RAM_START + 081h
         #define _AbitArray               PBA01, 000h
         #define _BbitArray               PBA02, 000h
    Compiled for a 18F252 you get this...
      PBA01          EQU     RAM_START + 01Ah
      PBA02          EQU     RAM_START + 01Ch
      PB01           EQU     RAM_START + 01Eh
      _AWORD         EQU     RAM_START + 01Fh
      _BWORD         EQU     RAM_START + 021h
      _DWORD         EQU     RAM_START + 023h
      _ABYTE         EQU     RAM_START + 025h
      _BBYTE         EQU     RAM_START + 026h
      _Cbyte         EQU     RAM_START + 027h
      _ABYTEArray    EQU     RAM_START + 028h
      _BBYTEArray    EQU     RAM_START + 032h
      _AWORDArray    EQU     RAM_START + 03Ch
      _BwordArray    EQU     RAM_START + 050h
    Interestingly, if you use any BANK modifiers, all that goes out the window.
    In fact, once you use a BANK modifier, all variables declared after it will be placed in that BANK and the following banks untill RAM is full, then it goes back to BANK0 and tries to fit things in the remaining space. So even if you only have 1 variable with a BANK2 modifier, you could be placing Lot's of variables in BANK2 and BANK3.
    I didn't know that till now.   Thanks for the question Mark!
    <br>
    Well, I'm still in "oh my God, I can't beleive it's doing that" mode.
    Taking a random sample of bit's and byte's and array's with random BANK1's ....
    Cbyte       VAR BYTE
    AWORD       VAR WORD
    BWORD       VAR WORD
    ABYTEArray  VAR BYTE(10)   BANK1
    DWORD       VAR WORD
    ABYTE       VAR BYTE
    BBYTE       VAR BYTE
    CBit        VAR Bit
    C2byte      VAR BYTE      BANK1
    B2BYTEArray VAR BYTE(10)  BANK1
    B2wordArray VAR WORD(10)
    A2WORD      VAR WORD
    B2WORD      VAR WORD
    A2BYTEArray VAR BYTE(10)  BANK1
    A2bitArray  VAR bit(10)
    D2WORD      VAR WORD
    A2BYTE      VAR BYTE
    B2BYTE      VAR BYTE
    A2WORDArray VAR WORD(10)
    C2Bit       VAR Bit
    B2bitArray  VAR bit(10)
    When compiled for a 16F877 looks something like this
      _A2WORDArray   EQU     RAM_START + 018h
      _AWORDArray    EQU     RAM_START + 02Ch
      _B2wordArray   EQU     RAM_START + 040h
      _BBYTEArray    EQU     RAM_START + 054h
      _A2WORD        EQU     RAM_START + 05Eh
      _A2BYTEArray   EQU     RAM_START + 080h  <-- BANK1 starts here
      _ABYTEArray    EQU     RAM_START + 08Ah
      _B2BYTEArray   EQU     RAM_START + 094h
      _C2byte        EQU     RAM_START + 09Eh
      _BwordArray    EQU     RAM_START + 09Fh
      _AWORD         EQU     RAM_START + 0B3h
      _B2WORD        EQU     RAM_START + 0B5h
      _BWORD         EQU     RAM_START + 0B7h
      _D2WORD        EQU     RAM_START + 0B9h
      _DWORD         EQU     RAM_START + 0BBh
      PBA01          EQU     RAM_START + 0BDh
      PBA02          EQU     RAM_START + 0BFh
      PBA03          EQU     RAM_START + 0C1h
      PBA04          EQU     RAM_START + 0C3h
      _A2BYTE        EQU     RAM_START + 0C5h
      _ABYTE         EQU     RAM_START + 0C6h
      _B2BYTE        EQU     RAM_START + 0C7h
      _BBYTE         EQU     RAM_START + 0C8h
      _Cbyte         EQU     RAM_START + 0C9h
      PB01           EQU     RAM_START + 0CAh
    At this point, I can't see a pattern, or a definate "Rule" that could account for the placements.
    A2WORD ends up in BANK0 even though it was declared after 3 BANK1 variables.
    AWORD and BWORD were defined prior to any BANK1 vars, and yet, still ends up in BANK1???????
    Does anyone see something I'm missing?
    <br>
    G4LCH's Avatar
    G4LCH Guest
    Smile I guess the question was not than dumb ;=)
    Thanks guys, I did not have a code space problem I just wanted to
    check that as I was switching banks that there could be a way to keep
    the byte alignment and hence speed.
    It come from programming on Mac/PC's where it can make big differences
    Thanks for al your input it was great to have more insight, I learnt even more
    which is fab and one important thing inspect the ASM file ;-)
    Mark
  1. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 09:01
  2. Memory use - how much do you use?
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 23:39
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 19:04
  4. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
