interrupt on USB activity
Results 1 to 3 of 3
    Billou's Avatar
    Billou Guest
    Default interrupt on USB activity
    I tried to write PBP programm with an interruption on USB bus activity.
    Here is my code ..
    http://www.picbasic.co.uk/forum/showthread.php?t=3434
    Any ideas ?
    Jul 2004
    CA
    CDC is using the Virtual COM Port Similar to a serial COM port. not the USB Port. Make sure you know the difference. CDC uses a serial communication Protocol, while the USB uses it's own protocol, stacks, etc.
    Srig
    Billou's Avatar
    Billou Guest
    Default usb com
    for sure, but CDC is th way to be recognise by PC. I use USB WITH CDC protocol.
    USB or USB CDC it doesn't change the way to code a USB com in PBP.
    For example : when you're waiting for a byte from the PC , you will use "USBin" command. The PC will send you a byte thru his virtual com port but for you it will come in PIC as a standart USB communication.
    So logicaly it will be possible to try to detect this activity... but i don't know how
  1. Easy HID Command -Response application
    By ptig185 in forum USB
    Last Post: - 22nd September 2010, 20:56
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 03:35
  3. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
  4. interrupt on USB com
    By Billou in forum USB
    Last Post: - 3rd March 2006, 01:45
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 02:07
