Pulsin
Results 1 to 6 of 6
Thread: Pulsin
    You guessed right. Setting Ports to Analogue is one of your housekeeping jobs.
    Nov 2004
    Calabasas, CA
    Thanks, What about the tris register, does this command set port pin to an output. If so, does it then remain in this output state?
    James
    I always set TRIS manually - it's only one instruction per Port. If PICBasic commands set it as well, then all's well and good, if they don't, then you've done it.
    Nov 2004
    Calabasas, CA
    You're a wealth of knowledge, thanks. Is that a pic of you?
    James
    Last I looked in the mirror it was pretty close. Would be kinda daft putting up a pic of somebody else. Perhaps one of Patrick Starfish (my hero) from Spongebob Squarepants fame.
  1. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 10:17
  2. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  3. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 13:52
  4. Pulsin to pulsout with up than 4MHZ crystal ?
    By RCtech in forum mel PIC BASIC
    Last Post: - 18th May 2006, 19:23
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 14:45
