16F684 Basic Functionality
Results 1 to 7 of 7
    Nov 2008
    Default 16F684 Basic Functionality
    Having a few problems getting some basic functions to work properly on a 16F684, not sure if I can see the forest through the trees now. Basically I can't get the toggle function to work, works fine if I set a pin to 1 then 0. Also, if I have a SEROUT pin on the same Port as a Pin I'm manually toggling the SEROUT works but the toggle doesn't, move the SEROUT to a different port and all's fine:
    '16f684
    DEFINE OSC 8 'Oscillator speed in MHz
    OSCCON  =   %01110111       'Page 20
    ANSEL   =   %00000000
    TRISA   =   %00000000
    TRISC   =   %00000000
    PortA   =   %00000000
    PortC   =   %00000000
    WPUA    =   %00000000
    CMCON0  =   %00000000
    ADCON0  =   %00000000
    ADCON1  =   %00000000
    Heart_Beat_LED  Var portC.1 'Output pin to LED for Heart Beat indication, Low is on.
    Heart_Beat_LED  =   0
    Terminal_TX     var	PortC.2	'Output pin to the dumb terminal or PC program on port C
    Start:
    'Uncomment subroutine 1, 2, or 3
    'Goto Subroutine_1
    'Goto Subroutine_2
    'Goto Subroutine_3
    goto Start
    Subroutine_1:   'This works.
        Heart_Beat_LED = 1
        Pause 1000
        Heart_Beat_LED = 0
        Pause 1000
        Goto Start
    Subroutine_2:   'Pin is "low" and can be seen cycling between 125mV and 75mV on a scope.
                    'both serial out's seen on terminal.
                    'If I move the Terminal_TX to PortA it works.
        Heart_Beat_LED = 1
        serout Terminal_TX,6,["1-Heart_Beat_LED",13,10]
        Pause 1000
        Heart_Beat_LED = 0
        serout Terminal_TX,6,["2-Heart_Beat_LED",13,10]
        Pause 1000
        Goto Start
    Subroutine_3:   'Doesn't work
        Toggle Heart_Beat_LED
        Pause 1000
        Goto Start
    Perth, Australia
    Strange. I have seen toggle do strange things before but cant remember what the problem was.
    Out of interest, does it work if you use the following instead of toggle:
    IF Heart_Beat_LED=0 THEN
    Heart_Beat_LED=1
    Heart_Beat_LED=0
    PAUSE 1000
    Default analog blues perhaps
    cmcon0 = 7 'Comparators off. CxIN pins are configured as<b> digital I/O</b>
    cmcon0 = 0'Comparators off. CxIN pins are configured as analog
    Nov 2008
    Quote Originally Posted by Kamikaze47 View Post
    Me too.
    Heart_Beat_LED=1
    Heart_Beat_LED=0
    PAUSE 1000
    Nada, doesn't work. Pin stays high, don't see any change with a scope. It always sees Heart_Beat_LED = 0.
    Interestingly enough, which I left off the earlier post, if I write:
    serout Terminal_TX,6,["1-Heart_Beat_LED = ",#Heart_Beat_LED,13,10]
    serout Terminal_TX,6,["2-Heart_Beat_LED = ",#Heart_Beat_LED,13,10]
    The value remains zero in each SEROUT.
    Nov 2008
    Thanks Joe S., I should know better. All is fine now.
    Sep 2009
    Default configure 16f690 for xtal osc
    Can't quite find the right place to ask this but anyway.....please bear with me..........
    Have scoured the 306 pages of the data sheet and still can't make my
    PIC16F690 oscillate at 12MHz. In PBP how do I configure it for ext crystal?
    Desperate, why do I find it so difficult? I'm only 70 yrs old.
    Cheers
    External Oscillator selection is performed from the CONFIGURATION BITS of this PIC.
    See section 14 of the Datasheet (and section 3 if you're really bored)... mine's only got 304 pages, so you must have the 'Professionals' copy.
    Use your programmer to select HS OSC manually at program time if you are connecting a 12MHz Xtal.
    Alternatively, embed the appropriate device CONFIG into your program... see for example...
    Finally, don't forget to include DEFINE OSC 12 somewhere at the top of your program to tell PBP that you're running at 12MHz, otherwise it will continue to think you're at 4MHz (the default).
  1. Indexer not indexing...a basic PBP problem??
    By jellis00 in forum General
    Last Post: - 24th March 2009, 16:53
  2. Loop with two motor and 2 sensors
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 18:05
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 01:56
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 22:10
