Single button function
Results 1 to 40 of 41
    Jun 2005
    Germany
    Post
    Hi, Alain,
    thanks for the fast reaction and the Code sample.
    I would like to build a "One Button Dimmer"
    1. Short Press Button T1: Toggle LED1 on/off or off/on.
    2. Long Press Button T1: Ramp the Light von LED1 up or Ramp the Light down depending on the one last "Long Press", Ramp direction toggle every "Long Press".
    3. Before power off store the last Ramp value
    See the schematic in the attachment
    Every help is welcome,
    Konrad
    Talking Slb 0587
    Hi, Vtt
    A look Here, may be ...
    http://www.electronique-diffusion.fr...lb0587&x=2&y=8
    some chips still on the market !!! ... and in my drawers ... LOL !
    Default Re: Slb 0587
    Due to my lack of knowledge, when facing same problem, I did the following - while user keeps button pressed, value of needed variable is being increased and value of waiting variable reset. As user releases the button, waiting variable is being increased, and after it reaches some value (say for 2 seconds), next chunk of code is required. I'd like to do the same with long press, but still can't figure how.
    Any ideas to add long press detection to this code?
    setuploop:
    if but2=0 then
    dlycnt=dlycnt+1 'increase debounce variable while button is pressed
    pause 1
    if BUT2=1 and dlycnt>100 then 'if button pressed long enough
    dlycnt=0
    high buz 'enable buzzer pin
    menuitem=menuitem+1
    lcdout $fe,1, #menuitem, " pressed "
    pause 5
    low buz 'disable buzzer
    goto setuploop
    OK
    Default Re: Single button function
    IF Button = Pressed THEN
    WHILE Button = Pressed
    LOOP
    I did it in the different way:
    setuploop:
    if but2=0 then
    ticker=ticker+1
    pause 1
    if ticker>1500 and  BUT2=0 then gasvla 'if long pressed, then exit and (or) go to selector item
    if BUT2=1 and dlycnt>100 then  'if short pressed, then do the rap
    ticker=0
    dlycnt=0
    menuitem=menuitem+1  'this is incremental variable, substitute another next time you need it
    lcdout $fe,$c0, " selection: " #menuitem," "  'debug just for case
    pause 1
    goto setuploop
    I did a setup to check for...... short press, then 2 second or 5 second then long press to enter program mode, for next for the timing, then go on to next check and goto's
     FOR A1= 1 TO 5        '<.1 SECONDS FOR TIMER
     PAUSE 3
     GOSUB RDSW
     if SWCH=0 then start
     NEXT A1
     HIGH 2
    read 1,A4 :PAUSE 10: C1=60*A4:C2=C1
     FOR A1 = 1 TO 100       '2 SECONDS FOR 8 HR
     PAUSE 8
     GOSUB RDSW
     if SWCH=0 then TIMER
     NEXT A1
     C1=28800      '8 HRS
     HIGH 5
     FOR A1 = 1 TO 100        'CHECK FOR PROGRAM 5 SEC TOTAL
     PAUSE 40
     GOSUB RDSW
     NEXT A1
     LOW 2:GOTO PROGRAM
    All the above methods block the program execution. If this is not a problem then it I guess ok.
    But if the PIC must do other things, it is better to have a ticker in a timer interrupt routine and count up when a key is pressed. Periodically check the ticker for the required value and decide what to do.
    That way, program does not stay in a closed loop until button release.
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 08:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
  4. Pushbutton code routine suggestions?
    Last Post: - 3rd September 2005, 01:02
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 16:44
