OT - power supply problem
Results 1 to 3 of 3
    Jan 2006
    Default OT - power supply problem
    OT, but I figured if anyone knew, you guys would.
    I have had 2 "wall wart" power supplies with this phenomenon thus far.
    When first purchased, my 12 volt 1 amp power supplies would pump out 12 volts when hooked up to a volt meter. I started noticing that on the output side of my voltage regulator, I was getting 8.7 volts instead of 5! So I checked the wall wart again, and it was pumping out 22.8 volts!!!
    So is this a problem I am causing, or does this happen to "wall-warts" sometimes?
    I am using a LM7805 to produce the 5v from the input source and I have a polarized cap on the output side.
    Most wall-warts are unregulated, and will output more than the rated voltage
    until you place a load on them. The LM7805 should still work just fine with this
    however since most flavors are rated up to around 35V MAX input.
    22V input shouldn't do much more than make your regulator run much hotter. It
    should still work fine.
    Are you 100% sure you don't have an LM7809 stuck in there, or maybe have
    your LM7805 wired in backwards? 8.7V out from an LM7805 is not good.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Thank you for making me go back and look into this problem deeper. It turns out it was stupid user error. A mistake in my multimeter settings.
    cheers
    -brian
  1. Power Up problem
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 04:38
  2. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 18:05
  3. Need advice for 74VDC power supply
    By Christopher4187 in forum Off Topic
    Last Post: - 4th March 2007, 21:54
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
  5. Regulated power supply problem
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 08:23
