How do I select the proper photo resistor for using the pot command
Results 1 to 6 of 6
    jessey's Avatar
    jessey Guest
    Default How do I convert the serout to lcdout?
    Hello Sougata,
    Thanks for your reply. How do I set up the code you gave me to work using the lcdout command? I managed to find an LDR that has dark resistance of 5K to 5.5K and it shows approximately 30 ohms with a very bright light shinning on it, that's an acceptable range?
    When I run the code you sent as modified below, I get weird charters on the Lcd for the 10,13 and it never makes it to the calibrated subroutine. I tried it initially using a 0.1 microfarad then tried a 0.01, 0.022, 0.047, 0.47 and even a 1 microfarad but no go, what other values would you suggest using? Or could it be the code is locking up due to 10,13 screwing it up? I don't understand what the 10,13 is all about, can you explain what it's for? I'm using a 2 X 16 character Lcd, can you tell me what I need to add to get it working with the Lcdout commands?
    For scale = 1 To 255
    POT PORTD.0,scale,B0
    If (B0 > 253) Then calibrated
    Next scale
    LCDOut $fe, 1,"Inc R or C.",10,13
    Stop
    calibrated:
    LCDOut $fe, $c0,"Scale= ",DEC scale,10,13
    jessey
    jessey's Avatar
    jessey Guest
    Default I got it to show scale but I had to a 10 mf cap, is that a little high?
    Hello Again Sougata,
    I got it to work with the code below. Using a 10 microfarad capacitor I get a value for scale of 204 and the B0 variable shows 255. I haven't tried in my program yet and I'm not familiar with the usual values used for the POT command but 10 microfarads seems a little high and I would think it would really slow down the read. Maybe if I get a different LDR closer to the 50K maximum value I might be able to get away with using a smaller value capacitor? Anyways I'll try it in my program to see how it works, in the meantime what do you think about having to use a 10 microfarad cap for the LDR?
    Next scale
    LCDOut $fe, 1,"S = ",DEC scale," B0 = ",DEC B0
    Stop
    calibrated:
    LCDOut $fe, $c0,"S = ",DEC scale , " B0 = ", DEC B0
    Stop
    jessey
    Feb 2005
    Kolkata-India
    Default 10 and 13 are linefeed and carraige return
    I am sorry you got confused with the 10 and 13. They just instruct your hyperterminal to make a new line so that you get the next reading on a next line. Good that you found out the solution to your LCDOUT and your code is okay. Now the calibration part :
    Well try it out with a 0.22uF. And run the program. Your B0=255 means that the program has calibrated the scale value for your circuit. Notedown the scale value and use it in your program without using anymore calibration. It is a one time process to get the full range out of the pot command. Actually the pot command charges and discharges your capacitor through this resistor (in your case the LDR) and finds the time constant. It makes the Input/Output to get a tristated sort of logic. The PICs have an inbuilt schmiddt trigger which allows the software to sense the discharge slope.
    Hope this helps
    Sougata
    jessey's Avatar
    jessey Guest
    Default Thanks Sougata
    Thanks Sougata,
    I managed to find a 0.22uF and it works great. Thanks for your much appreciated help.
    jessey
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Using the Pot command.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 17th August 2009, 20:23
  3. PBP2.50b and POT command problem ?
    Last Post: - 13th October 2008, 17:14
  4. Replies: 4
    Last Post: - 24th January 2007, 22:20
  5. pot command
    Last Post: - 25th November 2006, 04:12
