Originally Posted by
Qacer
I am using a PIC12F675. My datapin is GP0. The clockpin is GP1. The I2C device that I want to use is characterized as a slave-transceiver. The datasheet states that its "IC address C0: 1100000." Looking through the PBP manual, it says I2CWRITE DataPin,ClockPin,Control, {Address,}, Value, Label.
I am not quite sure what to put down in the Control option. I do not see any references to the Control option in the datasheet.
Use the adress of the slave-device as control.
Qacer
Also, if I want to read data from the I2C device, do I need to set TRISIO and GPIO to inputs before invoking the I2CREAD routine?
No.
Qacer
Another thing, the I2C datasheet does not state any pause between writing, so am I right to assume that I can just send multiple bytes in one I2CWRITE statement?
Yes. It depends on your slave-device what does happen....
