Input Noise
Results 1 to 14 of 14
Thread: Input Noise
    Interrupts alone can cause seriously erratic behaviour depeding on your
    program structure & how you're handling things getting in/out of the int
    handler.
    I would still look at isolation, but it may also have something to do with your
    interrupts. Can you post your interrupt handler?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Toronto
    Here is the interrupt handler:
    ' Interrupt Handler
        DISABLE INTERRUPT                        ' No interrupts past this point
    Main_Interrupt_Handler:
        ' PortB.0 Interrupt, Motor RPM Counter
    	IF INTCON.1 = 1 THEN
            IF Calibrating = 1 THEN
                Total_Pulses = Total_Pulses + 1
                IF System_Calibrated = 1 THEN
                    New_Position_Counter = New_Position_Counter + 1
                    IF New_Position_Counter >= (Pulses_Per_Position + Temp_Pulses) THEN
                        SELECT CASE Current_Direction
                            CASE Forward_Dir
                                Current_Position = Current_Position + 1
                                IF Current_Position > Total_Positions THEN
                                    Current_Position = 1
                            CASE Reverse_Dir
                                Current_Position = Current_Position - 1
                                IF Current_Position = 0 THEN
                                    Current_Position = Total_Positions
                        END SELECT
                        DEBUG 13, 10, "[ Position Change ] Current Position: ", DEC Current_Position, 13, 10
                        New_Position_Counter = 0
                        Temp_Pulses = 0
                INTCON.1 = 0
    	' PortB.1 Interrupt, Position 1 Sensor
    	IF INTCON3.0 = 1 THEN
            DEBUG 13, 10, "[ INTERRUPT ] Home Position Detected", 13, 10
                Pos1Found = 1
                Temp_Pulses = 0
    	    INTCON3.0 = 0
        ' PortB.2 Interrupt, Fault Relay Input
        IF INTCON3.1 = 1 THEN
            DEBUG 13, 10, "[ INTERRUPT ] AC Invertor Fault Detected", 13, 10
            AC_Fault_Detected = 1
            INTCON3.1 = 0
        ' USART Receive Interrupt
        IF PIR1.5 = 1 THEN
            'DEBUG 13, 10, "[ INTERRUPT ] USART Receive", 13, 10
            HSERIN [RS485_B0]
            SELECT CASE RS485_B0
                CASE RS485_STX
                    RS485_Receiving_Data = 1
                    RS485_Bytes_Received = 0
                    FOR i = 1 TO RS485_Buffer_Size
                        RS485_Data_Buffer[i] = 0
                    NEXT
                CASE RS485_ETX
                    RS485_Receiving_Data = 0
                    RS485_To_Address = RS485_Data_Buffer(0)
                    RS485_Command = RS485_Data_Buffer(1)
                    RS485_Parameter.HighByte = RS485_Data_Buffer(2)
                    RS485_Parameter.LowByte = RS485_Data_Buffer(3)
                    RS485_From_Address = RS485_Data_Buffer(4)
                    RS485_Parameter = RS485_Parameter - 10
                CASE ELSE
                    IF RS485_Receiving_Data = 1 THEN
                        RS485_Data_Buffer(RS485_Bytes_Received) = RS485_B0
                        RS485_Bytes_Received = RS485_Bytes_Received + 1
            END SELECT
            PIR1.5 = 0
    IntDone:
    	RESUME					' Return to main program
        ENABLE INTERRUPT
    This looks OK to me except for PIR1.5 = 0.
    The USART receive interrupt flag bit can only be cleared by reading RCREG
    until the buffer is empty. You're reading this only once in your int handler.
    If you receive more than a single byte of data it can cause problems. I would
    test the flag again before exiting this particular int handler sub-routine.
    I don't think this is causing the problem you're seeing, but it could be one if
    you're expecting PIR1.5 = 0 to clear the USART interrupt flag.
    What happens if you remove the encoder, and replace it with a push-button
    switch?
    Does pressing the switch to simulate the encoder logic on the int0 input pin
    work?
    If it works then I would have to suspect an isolation problem.
    -Bruce
    tech at rentron.com
    Jan 2006
    Toronto
    Bruce, putting the switch works fine so I also suspect its an isolation problem. I am going to try your sujestions and build a second power supply.
    Jan 2006
    Toronto
    I finally got it fixed.
    It turns out that the conduit I was using is made of aluminum not steel and for some reason it was not good enough to shield the 3 phase power cables to the motor. I changed it to steel and it works fine now.
    I also fixed the isolation problem thanks to your sugestions Bruce.
    Thanks everyone.
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  2. RB0 + Internal Pullup + Interrupt
    By Freman in forum mel PIC BASIC Pro
    Last Post: - 10th August 2009, 11:11
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 20:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
