If ... Then Gosub <> If ... Then Goto?
Results 1 to 7 of 7
    To keep track of IF...ENDIF, or indeed any other block statements which themselves could be nested (such as FOR...NEXT, or WHILE...WEND) it's convenient to indent the code for every block statement. The compiler ignores surplus indents and it makes it more human readable when looking at the code. Example...
    Start:
    	'	Set Dual-Colour LED
    	If PowerOn=1 then
    		High PowerOnLEDGreen
    		Low PowerOnLEDRed
    		If BatteryLow=0 then
    			High PowerOnLEDRed
    			Low PowerOnLEDGreen
    	Gosub ScanKeyboard
    	Goto DoCleverStuff
    This way you can easily track the preceeding IF statement associated with any corresponding ENDIF by just following the indented block.
    Why is Yoda wearing rubber gloves whilst doing hand-puppet Rabbit impressions?...
    oldtoddler's Avatar
    oldtoddler Guest
    Thumbs up
    Quote Originally Posted by Melanie
    Yep, this is how I do it.. I use only one space instead of tab.. way too many nested loops and whiles to fit in one line.. there you can find 5.. Wonder if there is any limit for loop levels?
    -->8-- <klipeti> --
      IF Mode then GoSub lcd	'				| |
      ADCIN AN3,IM			'				| |
      IF IM < 512 Then		' Virta ei vielä yli 0A		| | if_11
       ADCIN AN1,VM			' Mitataan jännite		| | |
       IF VM > Vp90 Then		' Jos yli +270V (90% * 300V)	| | | if_6
        Reg=1			' Regulaattori IGBT päälle	| | | |
        wr_fet=0			' 				| | | |
        PULSOUT WR_FET,latch	' 				| | | |
        Ikkunassa=1			'	 			| | | |
        While Ikkunassa		'				| | | | we_7
         IF Mode then GoSub lcd 	'				| | | | |
         ADCIN AN1,VM		'	 			| | | | |
    Well.. Maybe it has something to do with climate change.. o:-)
    As u know, Yoda comes from clean-air environment and he was fotographed in L.A... :-)
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 20:54
  3. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
