Implement a timer without using an interrupt
Results 1 to 4 of 4
    PR2 is is initialized to 255 on reset.
    With Timer2 prescaler & postscaler set to 16, it takes 16*255*16
    clock cycles before PIR1.1 is set.
    At 4MHz this = 65,280uS.
    65,280uS * 350 = 22.848 seconds.
    If you need ~5 seconds, increment Counter up to 76.
    76 * 65,280uS = roughly 4.961S + whatever program over-head you
    have in the process.
    P.S. You need Counter to be a "word" size if it's counting past 255,
    and you should initialize your Counter variable to 0 before Main, then
    clear it once it's reached your max count.
    if Counter = 350 then
    This will never be true since it will roll-over from 255 to 0
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Las Vegas, Nevada, USA
    Smile Thanks Bruce
    I am not sure why you mention "PR2 is initialized to 255 on reset". I have no idea what you are trying to tell me.
    However, your explanation and advice to change my Counter trigger to 76 did the trick with the addition of resetting the Counter to 0 when I turn the timer on.
    Works like a charm.
    Ken
    When Timer2 counts up to the value in PR2, PIR1.1 is set, and Timer2 is
    reset to 0. It doesn't over flow when it rolls-over from 255 to 0 like other
    8-bit timers.
    The time is takes for PIR1.1 to be set =;
    (prescaler)*(PR2)*(postscaler)*(instruction cycle time).
    Since PR2 is initialized to 255, and you're using both prescaler & postscaler
    set to 16, then (assuming a 4MHz osc) 16*255*16*1uS* your Counter value
    of 76 = 4.9 seconds.
    Look in the Timer2 section of your data sheet for the whole story..;o}
    Try placing PR2 = 127 in the startup section of your code to see the effect.
    -Bruce
    tech at rentron.com
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 23:49
  4. How to set interrupt for Timer 0
    Last Post: - 18th November 2006, 00:14
    Last Post: - 6th March 2005, 01:07
