Usart problem with 18F4550
Results 1 to 8 of 8
    Thumbs up
    thanks steve for helping me on the way again.
    i figured it out with your sample code and i'm back on track.
    thx again
    Oh I clapped my hands when I found this, thought i had got a working example of hserout...
    didnt work for me.........
    I changed it a little as I like to run at OSC 48 etc, and dont use a boot loader, and didnt need hserin, so just did a hserout and a 1 second pause to see if i could receive at the PC end, but I get the wrong chars, usually =_Y=_Y etc repeated
        '   Baudrate : 9600 Bauds
        '   Method :   Polling USART interrupts flags
        '   Pic Definition
            ' Using PIC 18F2550 @  48 MHZ        '
            DEFINE OSC 48
            clear
            ADCON1 = %00001111
        '   Hardware configuration
            TRISC  = %10000000    ' PORTC.7 is the RX input
                                  ' PORTC.6 is the TX output
        '   Serial communication definition
        '   Using internal USART and MAX232 to interface to PC
            DEFINE HSER_RCSTA 90h ' enable serial port,
                                  ' enable continuous receive
            DEFINE HSER_TXSTA 20h ' enable transmit,
                                  ' BRGH=1
            DEFINE HSER_BAUD 9600
            DEFINE HSER_CLROERR  1 ' automatic clear overrun error
        '   Alias definition
            RCIF VAR PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
            TXIF VAR PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
        '   Variable definition
            SerialData var byte
        '   Hardware initialisation
            pause 10 ' safe start-up delay
    toggle portb.0
           hserout [65,10,13] ' send it
    Also portC.1 goes high ?
    led flashes 1 second on and 1 second off so i'd say cpudiv etc is right.
    Have i done anything obviously wrong?
    ok double checked the hardware on the pc side, its a pl2303/usb cable, as my laptop nhas no com: ports.
    if i short pins 2/3 then i see what i type, so the hardware to that point is working.
    i then plug this into my dev board, which has a max232 on it, this is connected to the PIC via a dip switch on rc6/rc7. if i disconnect it from the pic with the switches and then short these, i see what i type again, so the max 232 is working both ways...
    I flip the switches and reconnect to the pic, and i get garbage on screen, about once a second, and the chr counter advances by 3, so its almost right, but not quite........
    May 2008
    Italy
    Below the EUSART setting for 48 Mhz as per Mr E pic calculator.
    DEFINE HSER_SPBRG 225 ' 9600 Baud @ 48MHz, 0,0%
    SPBRGH = 4
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    Al.
    I did have a look at the Mister_e tool, but it said it needed a dll i didnt have.
    Also still same, but then i found baudcon.4=1.......bingo! (Ok a friend pointed to it!)
    Seems i needed my bits the other way up...
    Other issue still remains, portc.1=high, but i see nothing in the above to cause it?
    No doubt its a quirk of using the Hw instead of the software routine.
    I could always consider it a power light....
    Quote Originally Posted by f_lez View Post
    Hi f_lez,
    check out post 10 in this thread. I had that problem too, this fixed it.
    http://www.picbasic.co.uk/forum/showthread.php?t=4994
  1. 18f4550 usb problem.. so im getting crazy..
    By MeSaKu in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 23:03
  2. byte Tx w/ USART 16f876a problem
    By GargamelDigi in forum mel PIC BASIC
    Last Post: - 15th July 2008, 06:50
  3. 18F4550 XTAL Problem
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 21:12
  4. USART Problem , but don't know where, in pc? or in PIC?
  5. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
