Usart problem with 18F4550
Results 1 to 8 of 8
    Angry Usart problem with 18F4550
    When i use a 18F4550 to communicate with the pc it will not work right.
    The interface between pic and PC is oke (RS232), because when i use a 16F876 with the same code it works fine.
    I've gone over the datasheet over and over and i think that is setup everything right.
    but just a simple character transfer does not even work.
    who can help me or has faced the same problem??
    p.s. USB etc works great, but now i also need Usart!!
    Here is the simple code that will not work.
    send char "A" to the PC
    at 2400 baud, no data received, at lower or higher speed "crap" is received.
    ' simple usart test pic18f4550
    define osc 20
    trisc.7=1 'portc.7 input RX
    trisc.6=0 'portc.6 output TX
    baudcon.3=0'BRG16 :0=8 bit baud generator
    txsta.2=0 'BRGH 0=low speed
    SPBRG=129 '2400 baud see datasheet
    txsta.4=0 'SYNC 0=asynchoon
    rcsta.7=1 'SPEN serial port enable
    txsta.6=0 'TX-9 :8 bit data
    txsta.5=1 'TXEN transmit enable
    ADCON1=15 'all ports digital i/o
    start:
    Hserout [$41] 'send char A at 2400 baud
    pause 2000
    goto start
    what i'm i doing wrong ???????????
    Feb 2005
    Essex, UK
    I too have had problems using USART on the 18F2550.
    Try this piece of code below. It works fine on my PIC now. It will basically echo back what ever you put on the PIC. Obvioulsy you can change the bottom lines to just send data if you wish.
    Good luck and i hope it helps.
        '   Program to echo incoming serial data
        '   Baudrate : 9600 Bauds
        '   Method :   Polling USART interrupts flags
        '   Pic Definition
            ' Using PIC 18F2550 @ 20MHZ and bootloader
            Clear
            DEFINE OSC 20
            DEFINE LOADER_USED 1
            ADCON1 = %00001111
        '   Hardware configuration
            TRISC  = %10000000    ' PORTC.7 is the RX input
                                  ' PORTC.6 is the TX output
        '   Serial communication definition
        '   Using internal USART and MAX232 to interface to PC
            DEFINE HSER_RCSTA 90h ' enable serial port,
                                  ' enable continuous receive
            DEFINE HSER_TXSTA 20h ' enable transmit,
                                  ' BRGH=1
            DEFINE HSER_BAUD 9600
            DEFINE HSER_CLROERR  1 ' automatic clear overrun error
        '   Alias definition
            RCIF VAR PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
            TXIF VAR PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
        '   Variable definition
            SerialData var byte
        '   Hardware initialisation
            pause 10 ' safe start-up delay
        if RCIF then            ' incomming data?
           hserin  [Serialdata] ' take it
           hserout [serialdata] ' send it
    Thumbs up
    thanks steve for helping me on the way again.
    i figured it out with your sample code and i'm back on track.
    thx again
    Oh I clapped my hands when I found this, thought i had got a working example of hserout...
    didnt work for me.........
    I changed it a little as I like to run at OSC 48 etc, and dont use a boot loader, and didnt need hserin, so just did a hserout and a 1 second pause to see if i could receive at the PC end, but I get the wrong chars, usually =_Y=_Y etc repeated
        '   Pic Definition
            ' Using PIC 18F2550 @  48 MHZ        '
            DEFINE OSC 48
            clear
            ADCON1 = %00001111
                                  ' BRGH=1
        '   Alias definition
            SerialData var byte
    toggle portb.0
           hserout [65,10,13] ' send it
    Also portC.1 goes high ?
    led flashes 1 second on and 1 second off so i'd say cpudiv etc is right.
    Have i done anything obviously wrong?
    ok double checked the hardware on the pc side, its a pl2303/usb cable, as my laptop nhas no com: ports.
    if i short pins 2/3 then i see what i type, so the hardware to that point is working.
    i then plug this into my dev board, which has a max232 on it, this is connected to the PIC via a dip switch on rc6/rc7. if i disconnect it from the pic with the switches and then short these, i see what i type again, so the max 232 is working both ways...
    I flip the switches and reconnect to the pic, and i get garbage on screen, about once a second, and the chr counter advances by 3, so its almost right, but not quite........
    May 2008
    Italy
    Below the EUSART setting for 48 Mhz as per Mr E pic calculator.
    DEFINE HSER_SPBRG 225 ' 9600 Baud @ 48MHz, 0,0%
    SPBRGH = 4
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    Al.
  1. 18f4550 usb problem.. so im getting crazy..
    By MeSaKu in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 22:03
  2. byte Tx w/ USART 16f876a problem
    By GargamelDigi in forum mel PIC BASIC
    Last Post: - 15th July 2008, 05:50
  3. 18F4550 XTAL Problem
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 20:12
  4. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  5. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 17:56
