PIC12F675 trouble
Results 1 to 6 of 6
Threaded View
    russman613's Avatar
    russman613 Guest
    Default PIC12F675 trouble
    Hey all,
    i am still struggling with what seems like eratic behavior with my PIC12F675.
    I am trying to build an IR detection array thats smarter than a 555 timer or another hardwired 38500 oscillator and figured the small and tidy footprint of a 12F675 would be ideal.
    right now, i am at the stage where i am trying to get IR LED to flash at 38500MHz for about 10ms. it seems to work fine, but when i add some "smarts" code, the whole thing stops working. here is the following code i am adding.
    ' ... Problem is between here
    if (leftcount = duration) then
    for i = 1 to 3
    high ledsignal
    low ledsignal
    next i
    low ledsignal
    ' ... and here
    to my mainline, the chip wont start.
    the same happens if i add:
    freqout gpio.3, 10, 38500
    instead of the ASM delay block. I went down the ASM block path because it seems that freqout will not work with the 12F675 though i can't find that explicitly stated anywhere.
    Bottom Line Issue:
    It seems that when i add code that the chip does not like, it won't even start - the status LED blink i have at the top of my code won't even activate etc - nothing happens.
    I am using a USB melabs programmer. i disconnect the USB from my computer between flashes to make sure i don't fry anything. i am using MicroCode studio 2.3.0.0 and PicBasic PRO compiler 2.46.
    everyhing is soldered together to eliminate any potential of bad connections. i am using the following parts (http://www.hobbyengineering.com/H1765.html, http://www.hobbyengineering.com/H1992.html) without the 4Mhz resonator installed on the prototype board.
    gpio.0 is a regular old red LED with a 220 ohm resistor on it.
    gpio.3 is the detect from the IR Receiver (http://www.parallax.com/detail.asp?product_id=350-00014)
    gpio.5 is the IR LED out with a 1K resistor (http://www.parallax.com/detail.asp?product_id=350-00017)
    i have a .1uf bypass capacitor on the +5v and Ground leads of the detector
    any thoughts or suggestions on what i am missing would be appreciated. probably something simple and silly.
    it sure is frustrating. with that if block in there, the thing won't even start, i yank it out and it seems to work fine again.
    is there a possibility that, since i am using the internal oscillator, i have overwritten some config (calibration) space or something that ensures the internal oscillator runs as it should? This question is nagging at me in the back of my mind.
    here is the full code listing:
    ' Defines that set up the PIC
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT ' Internal Oscillator
    @ DEVICE pic12F675, WDT_ON ' Watchdog Timer
    @ DEVICE pic12F675, PWRT_ON ' Power-On Timer
    @ DEVICE pic12F675, MCLR_OFF ' Master Clear Options set to Internal
    @ DEVICE pic12F675, BOD_ON ' Brown-Out Detect
    @ DEVICE pic12F675, PROTECT_OFF ' Code Protect off
    @ DEVICE pic12F675, CPD_OFF ' Data EEPROM Protect off
    'define xtal 4 ' don't think i need this - cant find it in the .inc
    define OSC 4
    ' Initialise my Registers
    TRISIO=%00001000 ' all output except gpio.3 is input
    CMCON=%00000111 ' comparator module reg 6-1 page 35. Disable all
    ANSEL=%00000000 ' A/D config reg 7-2. Set all pins to digital
    'ADCON0=%00000000 ' reg 7-1 not required but shuts off A/D control
    ' Degine PINs
    ledSignal var GPIO.0
    leftIRLed var GPIO.5
    irDetect var GPIO.3
    ' Constants
    duration con 100
    ' Variables
    i var word ' Genral purpose counter
    dur var word
    leftCount var word
    ' Code Mainline
    ' Blink the status led so we know we're ok.
    high ledSignal
    pause 2000
    low ledSignal
    pause 2000
    'Mainline loop....
    MainLoop:
    ' Check to see if we have activity on the left LED.
    gosub LeftIR
    for i = 1 to 3
    high ledsignal
    low ledsignal
    next i
    low ledsignal
    ' ... and here
    pause 20
    Goto MainLoop
    ' Subroutines ...
    '1/38500 = 0.000026
    LeftIR:
    leftCount = 0
    dur = duration
    asm
    cycleLeft
    BSF GPIO,5 ;1uS Begin HIGH duty cycle
    NOP ;2uS each nop is 1uS long
    NOP ;3uS
    NOP ;4uS
    NOP ;5uS
    NOP ;6uS
    NOP ;7uS
    NOP ;8uS
    NOP ;9uS
    NOP ;10uS
    NOP ;11uS
    NOP ;12uS
    NOP ;13uS
    BCF GPIO,5 ;1uS Bigin Low
    NOP ;14uS
    NOP ;15uS
    NOP ;16uS
    NOP ;17uS
    NOP ;18uS
    NOP ;19uS
    NOP ;20uS
    NOP ;21uS
    NOP ;22uS
    BTFSS _leftCount ;23,us <- this line causes a problem it seems too.
    decfsz _dur, 1 ;24uS
    goto cycleLeft ;26uS
    endasm
    ledSignal = ~GPIO.3
    Last edited by russman613; - 27th February 2006 at 16:32. Reason: tryint to add an attachment
  1. Pic12F675 serial voltmeter
    By GioppY in forum Code Examples
    Last Post: - 20th November 2010, 14:20
  2. PIC12F675 problem with port 5
    By NL2TTL in forum mel PIC BASIC
    Last Post: - 5th June 2009, 02:23
  3. MCLR causing trouble . .
    By shahidali55 in forum General
    Last Post: - 21st December 2007, 13:20
  4. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 16:04
  5. Erratic PIC12F675 behavior
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:46
