write to EEPROM and interrupt
Results 1 to 8 of 8
    Miami, Florida USA
    Default Re: write to EEPROM and interrupt
    swr999, I have used the "DEFINE WRITE_INT 1" directive with my 18F parts and have had no problems. The READ instructions are not to my knowlege prone to disruption with interrupts enabled.
    Hi. Is this a PBP3 DEFINE? I don't see this in my PBP 2.60 manual. What does it do?
    Anonymous
    Mar 2008
    DEFINE WRITE_INT 1 is used to avoid write errors during a WRITE to EEPROM which might otherwise possibly be caused by an interrupt occurring during the write. The functionality is that it disables interrupts just prior to executing a WRITE instruction, and re-enabls interrupts after the WRITE completes. Appears to be strictly a PBP3 feature.
    Mar 2008
    With regard to the "DEFINE WRITE_INT 1" directive, it appears to be available at least from PBP 2.50 onwards. I misspoke above^^^. Apologies.
  1. Can't ID interrupt source with this IntHandler??
  2. Replies: 5
    Last Post: - 29th May 2008, 19:03
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  5. WRITE TO Eeprom
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 05:33
