write to EEPROM and interrupt
Results 1 to 8 of 8
    Mar 2008
    Default Re: write to EEPROM and interrupt
    I'm going to try this. Thanks!
    Also, does the same apply to EEPROM reads? I assume a READ instruction can get messed up if the interrupt occurs at just the right time during the READ?
    swr999, I have used the "DEFINE WRITE_INT 1" directive with my 18F parts and have had no problems. The READ instructions are not to my knowlege prone to disruption with interrupts enabled.
    EN82fn
    Miami, Florida USA
    Hi. Is this a PBP3 DEFINE? I don't see this in my PBP 2.60 manual. What does it do?
    Anonymous
    Mar 2008
    DEFINE WRITE_INT 1 is used to avoid write errors during a WRITE to EEPROM which might otherwise possibly be caused by an interrupt occurring during the write. The functionality is that it disables interrupts just prior to executing a WRITE instruction, and re-enabls interrupts after the WRITE completes. Appears to be strictly a PBP3 feature.
    Mar 2008
    With regard to the "DEFINE WRITE_INT 1" directive, it appears to be available at least from PBP 2.50 onwards. I misspoke above^^^. Apologies.
    Mar 2008
    Thanks Dave. My "issue" is that I have a 10-mS interrupt running to keep track of elapsed time. I have several EEPROM writes and since EEPROM writes take a while I don't want to lose time by stopping the interrupt for every write.
    I did a test program where I repeatedly wrote to EEPROM with a 'random' WORD. For each write I then read back the value that got stored in EEPROM. It turns out that the error rate due to interference from the interrupt was quite low, about 0.04% (~400 errors in a million writes). So what I ended up doing was to do each write with a call to a subroutine:
    EEwriteWord:
    WRITE addr,xW.byte0:WRITE addr+1,xW.byte1
    READ addr,xR.byte0: READ addr+1,xR.byte1
    IF xR != xW then
    INTCON.7=0
    INTCON.7=1
    This seems to be working well. While the EEPROM write takes several mS the READ is pretty fast, so this doesn't add too much overhead.
  1. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  2. Replies: 5
    Last Post: - 29th May 2008, 18:03
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  4. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  5. WRITE TO Eeprom
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 04:33
