Newbie: Trying to blink a LED
Results 1 to 7 of 7
    Default intrc
    Quote Originally Posted by paul borgmeier View Post
    JackPollack,
    The following worked great on my 16F88:
    ;@ DEVICE INTRC_OSC_NOCLKOUT, MCLR_OFF, PROTECT_OFF, WDT_OFF
    OSCCON = $60
    LOW PORTB.1
    LOOP:
    Toggle PORTB.1
    Pause 1000
    GoTo LOOP
    Notice that I commented out your fuse settings. I suggest picking them in the EPIC menu until you can get it running. My best guess is that INTRC_OSC_NOCLOCKOUT is not a correct setting but I could not verify. (I use MPASM exclusively and had the fuses set as shown in the attached.) As a check, I had pin 5 tied direct to ground, pin 14 tied direct to 5V, and had an LED between pin 7 and ground. Again, Good Luck
    Oh, also see: http://www.picbasic.co.uk/forum/show...ighlight=16f88
    Paul Borgmeier
    Salt Lake City, Utah
    USA
    paul
    i agree intrc_osc_noclockout
    does not seem corect pic manual state it has 3 noclock setting
    and three osc speed 4 - 8 and adj
    cant seem to find the corect syntax though
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    it turns out "INTRC_OSC_NOCLKOUT" is correct (see m16f88.inc in your pbp folder). The code I posted in this thread worked for me - 1 second delays were one second. I did not use the @ device line (hence, it is commented out) but picked them from the menu in MPLAB (I do not use PM).
    I am not sure what problems you are having or what you are asking here?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Newbie question about switch + led
    By mradde in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 18:40
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. Novice 16F83A BLINK LED program help
    By owali in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 06:02
  5. LCD will not start
