MCS/EPIC (parallel) problems
Results 1 to 4 of 4
    Default MCS/EPIC (parallel) problems
    No matter what I've tried I can't get the programmer to remember the setup port, which is LPT1. As soon as a new compile is called I have to go back in and reset the com port. I believe this should be saved in one of the program files. All this came about after moving the whole show from a desktop running Win95 to a laptop running XP. Why doesn't the MCS have a LPT listing in the drop downs, there all serial com1,com3 port ID's. I can program but it's a pain to remember to pick a port each time. Is ther something I am overlooking?
    Quote Originally Posted by fowardbias View Post
    .ini file somewhere?
    The programmer's are plug-ins. It would seem to me that the problem isn't in MCS, but in the programmer add-in software. I'd be checking over there, not in the MCS directory.
    Dec 2005
    In EPICWin, the Epic Port is set under the File menu. There's an Auto option that finds my LPT1 connected programmer.
    Smile No problems now
    Thanks for the info, everything is OK now, all I do is click program and it works. Don't even have to click on AUTO. Working great!
  1. problems with parallel LCD
    By Brown in forum mel PIC BASIC
    Last Post: - 12th June 2008, 05:37
  2. resistor in parallel with a thermistor
    By Pic_User in forum General
    Last Post: - 13th March 2007, 02:42
  3. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 15:38
  4. Goto inside a gosub??? Problems...
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 13th October 2005, 13:17
  5. Help with a Parallel I/O to Machine Interface?
    By john meiers in forum mel PIC BASIC Pro
    Last Post: - 16th September 2005, 19:50
