Timer Questions
Results 1 to 10 of 10
Thread: Timer Questions
    65,535 - 50,000 should be 65,536 - 50,000. Your load value would be 15536.
    It takes 65,536 cycles (0 to 65,535 + 1 additional cycle) for the 16-bit
    overflow or roll-over from 65,535 back to 0.
    Why then do I have to preload the timer with 15543 to make it dead on? Is this just a difference in osc frequency.
    Because the timer is still counting while you're doing things after it rolls-over.
    You need to compensate for time passed (timer counts) while your program is
    doing something after the roll-over. The timer is still counting during this time
    frame.
    You can either write an adjusted value to the timer, or simply "add" your real
    value to the existing count already held in the timer registers.
    Adding the real value to the existing timer count is the prefered method as
    long as your program doesn't tinker around long enough to where adding to
    the count would cause immediate over-flow after the add.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hangover, Germany
    Red face
    If the time is not precise enough for you, you can use CCP1 in order to restart Timer1 automatically.
    But I think it is to heavy for a beginner.
    Oh, the time is plenty close enough for what I'm doing. I just asked so I could learn and take notes.
    Thanks agin for the help...
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 23:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 08:41
