How to calculate machine time in basic code?
Results 1 to 4 of 4
    May 2005
    Default How to calculate machine time in basic code?
    Ex.
    Used 4 Mhz
    If porta.0 =1 then
    Portb.1=1
    Else
    Portb.2=1
    Italy
    Execution Time Measurement
    The oldest timing trick is to drive an output bit high when
    entering a routine, and then low as we exit. Probe the port
    with an oscilloscope and measure the time the bit is set.
    You can run your PBP program in the MPLAB simulator and use the
    StopWatch function to get the timing of the commands.
    (Menu Debugger\Stopwatch).
    Best regards,
    Luciano
    May 2005
    We Used microcode studio plus software
    Sep 2005
    Campbell, CA
    A way that I often use is to compare the execution against a hardware timer.
    The example below works for an '8720 running at 20Mhz. You will have to modify accordingly if you use a different processor or XTAL.
    DEFINE OSC 20
    DEFINE NO_CLRWDT 1 ' Don't waste cycles clearing WDT
    DEFINE _18F8720 1
    DEFINE HSER_RCSTA 90H
    DEFINE HSER_TXSTA 20H
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE LOADER_USED 1
    Define USE_LFSR 1
    TRISC = %10111111 ' Hardware serial port on PORTC.7,PORTC.6
    PSPCON = %00000000 ' No PSP
    MEMCON = %10000000 ' No External Memory
    CMCON = %00000111 ' No Comparator used, turn it off
    T0CON = %10001000 ' No Prescaler,16 bit
    TimerValue VAR WORD
    RealTime VAR WORD
    TestArray VAR BYTE[3600]
    DummyVal VAR Byte
    Restart:
    Intcon.2 = 0
    TMR0H =0
    TMR0L =0
    'Put code to be timed here
    TimerValue.LowByte = TMR0L
    TimerValue.Highbyte = TMR0H
    IF INTCON.2 = 1 THEN
    HSEROUT ["OVERFLOW - User different prescaler value",13,10]
    HSEROUT ["Execution Time = ",#TimerValue, " Cycles, ",#TimerValue/5," Microseconds",13,10,10]
    HSEROUT ["Press any key to restart",13,10]
    HSERIN [DummyVal]
    GOTO Restart
    Charles Linquist
  1. PIC BASIC TLC5940 code
    By eletrokat in forum mel PIC BASIC Pro
    Last Post: - 8th May 2010, 22:01
  2. Making Program Code Space your playground...
  3. 122x32 GLCD basic code
    Last Post: - 21st April 2008, 18:46
  4. Error code [112]/[113]
    By Dj tempo in forum General
    Last Post: - 17th June 2007, 17:15
  5. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 20:21
