How i ken read 7.2v with pic
Results 1 to 11 of 11
    serandre's Avatar
    serandre Guest
    I need to read a car battery, it ranges from 10v to 14.8v. In my circuit i have used a zener 10v to drop the voltage to 0-4.8v.
    Should i modify it to use voltage divider (10K/5K) instead ?
    Sorry eletronic is just a hobby to me, just learning :-)
    You should use the voltage divider with simple resistor... also add a 10-100nF at the PIC a/d input to smooth the results. It's amazing how much noise you can remove. Also, doing multiple reading then average them to avoid odd results it's just a better practice in, at least, car application.
    Quote Originally Posted by serandre
    I need to read a car battery, ...i have used a zener 10v to drop the voltage to 0-4.8v.
    Hi, Serandre
    Your Zener idea is not so bad ... but zener voltage is not stable with temp .!!! so, your measurement will be somewhat false ( in a car temp is not so constant ...).
    There would be a simple solution : use a cheap TL431 trimmable "zener" instead of the diode. see TL431 datasheet for that.
    http://pdf1.alldatasheet.com/datashe...OLA/TL431.html
  1. How to read PIC serial no. from EEPROM with PBP?
    Last Post: - 11th December 2009, 11:27
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  5. Controlling power to a PIC with another PIC
    By jswayze in forum Off Topic
    Last Post: - 28th May 2005, 20:44
