How i ken read 7.2v with pic
Results 1 to 11 of 11
    For most PICs the recommended maximum input impedance is 10K... although it does vary (example 12F675 it's 2.5K). I've actually used the 12F675 with the same 10K input circuitry I use with a 16F876 and the same default 50uS settling time without problems. I don't use ADCIN but prefer to set and poll the GO/DONE bit for a completed conversion. Like with all things, it's a case of try it and see, and if it works for you - use it. For Battery-Low applications with Comparator Inputs, I've had 470K/220K R1/R2 combinations before now just to keep the current down.
    Great, thanks you two!
    Well, I've learned my 1 thing for today. I guess I can take the rest of the day off.
    But before I do that, let's see if we can finish off jetpr's question.
    Assuming now that R1 can always be 10K (or 2.5K), we can forget about the guessing part and just calculate R2 with the same formula.
    Vin = 7.5 <-- max Input to voltage divider
    Vout = 5 <-- max Output voltage to pic
    R1 = 10000
    R2 = R1/(1-(Vout/Vin))-R1
    R2 = 10000/(1-(5/7.5))-10000
    R2 = 20000 ohms
    Hmmm, Nice round numbers too.
  1. How to read PIC serial no. from EEPROM with PBP?
    Last Post: - 11th December 2009, 11:27
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  5. Controlling power to a PIC with another PIC
    By jswayze in forum Off Topic
    Last Post: - 28th May 2005, 20:44
