too many interrupts
Results 1 to 6 of 6
    Hangover, Germany
    I think you turn on and off the Interrupt-enable-bits in order to handle the waste off interrupts....
    Just enable an interrupt,
    clear the interrupt-flag inside the Interrupt-service-routine,
    and wait inside your Main-Loop forever.
    And look into the PBP-help for such directives as DISABLE... !
    Feb 2005
    Kolkata-India
    Default You should end your interrupt routine with a resume
    PBP handles interrupt in a rather lazy way. It traces an interrupt by polling the interrupt flags and when found flags it in software, clears the hardware flag and jumps to the on interrupt routine after it has fininshed the current execution.
    So you should :
    1. Place the on interrupt statement in top part of your code
    2. Always end it with a resume (otherwise it executes it forever)
    3. To temporarily disable interrupt, just clear the int sources, without turning off the global bit.
    Sougata
    trying's Avatar
    trying Guest
    thanks for the replys. Sorry but I did leave out the disable at the interrupt handlers when I posted. (long night). sougata would please show me more of what you mean. I'm just getting started at this.
    Feb 2005
    Kolkata-India
    Default Do Not have much time
    I have hastily modified your code. It does a red blink normally , but when you pull down the mode pin it goes to the interrupt routine and does a green blink there. Hope this helps.
    @ DEVICE pic16f630
    @ DEVICE pic16f630, INTRC_OSC_NOCLKOUT
    @ DEVICE pic16f630, WDT_ON
    @ DEVICE pic16f630, MCLR_OFF
    @ DEVICE pic16f630, CPD_OFF 'MODE TEST
    @ DEVICE pic16f630, BOD_OFF 'BOARD TEST
    @ DEVICE pic16f630, PWRT_ON
    @ DEVICE pic16f630, PROTECT_OFF
    DEFINE OSC 4             ' Tell PBP that the PIC is running @ 4MHz
    ON INTERRUPT GOTO INT_GREEN  ' DEFINE THE PBP INTERRUPT HANDLER HERE
    DISABLE                  ' DO NOT PROCESS THE INERRUPT CALLS NOW
    CMCON = 7                'COMPARATOR OFF
    VRCON = 0                'VOLTAGE REF. DISABLE
    TRISA = %00011100        'MAKE A.2, A.3, A.4 INPUTS
    TRISC = %00000000        'MAKE ALL PORTC OUTPUTS
    'SETUP THE INTERRUPT PROPERTIES HERE********************************************
    OPTION_REG = 0           'ENABLE WEAK PULLUPS (CLEAR RAPU), INTERRUPT ON FALLING EDGE
    IOCA       = 0           'DISABLE INTERRUPT ON CHANGE
    WPUA       = %00111111   'WEAK PULLUPS ON PORTA
    INTCON     = 0           'LET INTERRUPTS BE-OFF AT THIS MOMENT
    ' ALIAS-SYMBOL  DEFINITIONS GOES HERE //////////////////////////////////////////
    SYMBOL SENSOR = PORTA.2 'TRIGGERING DEVICE PIN 3
    SYMBOL MODE   = PORTA.4 'MODE BUTTON (FLASH/LONG) PIN 12 INPUT
    SYMBOL LED    = PORTA.5 'LED POWER UP PIN 2 OUTPUT
    SYMBOL RED    = PORTC.3 'RED LED PIN 7 OUTPUT
    SYMBOL GREEN  = PORTC.4 'GREEN LED PIN 6 OUTPUT
    ' END OF ALIAS-SYMBOL  DEFINITIONS  ////////////////////////////////////////////
    ' DEFINE VARIABLES HERE ////////////////////////////////////////////////////////
    I VAR BYTE                 ' TO BE USED IN FOR-NEXT LOOP
    ' INITIALIZATION ROUTINE ///////////////////////////////////////////////////////
    LED   = 0                  ' TURN-OFF THE POWER LED
    RED   = 0                  ' TURN-OFF THE RED LED
    GREEN = 0                  ' TURN-OFF THE GREEN LED
    LED = 1                    ' TURN-ON THE POWER LED
    PAUSE 4000                 ' POWER UP OK
    LED = 0                    ' NOW TURN IT OFF
    ' END OF INITIALISATION ROUTINE ////////////////////////////////////////////////
    INTCON = $90               ' SET UP THE GIE BITS AND RA2 INT BIT
                               ' TO ENABLE INTERRUPT PROCESSING
    ENABLE   ' INSTRUCT THE COMPILER TO PUT THE INTERRUPT HANDLING CALLS FROM NOW ON
    '////////////// THE MAIN ROUTINE THAT DOES SHORT RED FLASH /////////////////////
    MAIN:
    RED = 1                    ' TURN-ON THE RED-LED
    I   = 0                    ' RESET THE VARIABLE (FOR-NEXT LOOP)
    FOR I = 1 TO 200           ' DO A PAUSE IN A LOOP 200 X 5 = 1000mS
    PAUSE 5                    ' REDUCES INTERRUPT PROCESSING LATENCY BY PBP
    NEXT I
    RED = 0
    NEXT I
    GOTO MAIN                  ' DO-IT FOR-EVER
    DISABLE ' INSTRUCT THE COMPILER NOT TO PUT THE INTERRUPT HANDLING CALLS FROM NOW ON
    '/// THE ACTUAL INTERRUPT HANDLER IS RIGHT BELOW ///////////////////////////////
    INT_GREEN:
    INTCON = $80               ' CLEAR THE INTERRUPT FLAG BUT KEEP GLOBAL ENABLED
                               ' OTHERWISE PBP WILL RE-ENTER THIS ROUTINE
    LED   = 1                  ' ON-TILL IN THIS ROUTINE
    RED   = 0                  ' TURN-OFF THE RED LED IF IT WAS ON BY A PREVIOUS INSTANCE
    GREEN = 1                  ' TURN-ON THE GREEN TO SHOW THAT INSIDE THIS ROUTINE
    PAUSE 1000                 ' WAIT A SECOND
    GREEN = 0 : PAUSE 1000     ' TURN-OFF AND WAIT
    GREEN = 1 : PAUSE 1000     ' TURN-ON AND WAIT
    LED = 0                    ' GREEN-BLINK DONE NOW TIME TO QUIT
    INTCON = $90               ' TURN-ON THE RA2 INTERRUPT BIT  FOR FURTHER PROCESSING
    RESUME                     ' GO BACK TO WHAT IT WAS DOING
    ENABLE
    BTW I commented out the device command as I use MPASM and it compiled okay. Hope this helps.
    Copy the code and paste it in MICROCODE STUDIO for better readability.
    Sougata
    trying's Avatar
    trying Guest
    Default thanks
    thanks sougata it compiled with cdlite. but I have not had time to play with it.
    But it has helped me understand a few things better. I'm learning 1 project at time thanks again
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 06:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
