Help with STR ArrayVar\n\c with SerIn2
Results 1 to 20 of 20
    Change skip1 to skip 1.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Almightyrastus's Avatar
    Almightyrastus Guest
    Ok thanks, I fixed the skip 1 bit and recompiled, still no luck, still getting the same error on both lines that contain the STR command (there is another one just after this to save some more stuff).
    Can you post the variable declarations?
    Must be something there that your missing.
    The above example compiles fine. Is there anything different?
    'Define variables
    MENU var BYTE 'Menu variable
    TIME var BYTE(11) 'Time variable
    WARN var BYTE 'Warning variable
    LAT var BYTE(10) 'Latitude variable
    LONG var BYTE(11) 'Longitude variable
    NS var BYTE 'North/South variable
    EW var BYTE 'East/West variable
    SPD var BYTE(6) 'Speed variable
    DIR var BYTE(6) 'Direction variable
    DATE var BYTE(6) 'Date variable
    ALT var BYTE(5) 'Altitude in m variable
    ALTU var BYTE 'Altitude units
    HDOP var BYTE(5) 'Horizontal dilution of precision
    SAT var BYTE(2) 'Satellites used
    METRE var WORD 'Height in meters variable
    AFEET var WORD 'Height in feet variable
    TEMP var BYTE 'Temp. for altitude conversion
    MULT var WORD 'Multiplier for altitude conversion
    ALTVAR var BYTE 'Set number for times round loop
    ALTF var BYTE(5) 'Altitude in feet storage
    'setup interrupts
    OPTION_REG = $7f 'Enable PORTB pull-ups and rising edge trigger
    INTCON = $90 'Enable INTE (port b, pin 0) interrupt
    MENU = "0" 'Clear the menu variable
    ON INTERRUPT GOTO INT 'Define interrupt handler
    'Startup Screen
    PAUSE 100 'Allow LCD to power up for 750ms
    LCDOUT $FE, 1 'Clear screen and display information
    LCDOUT "GPS Display"
    PAUSE 500 'Startup screen pause time
    'Main program
    'First collect data from GPRMC and GPGGA strings
    RXLOOP:
    SERIN2 PORTB.1, 188, 3000, RXERROR, [WAIT ("GPRMC"), skip 1, STR TIME\11\",", STR WARN\1, skip 1, STR LAT\10\",", STR NS\1, skip 1, STR LONG\11\",", STR EW\1, skip 1, STR SPD\6\",", STR DIR\6\",", STR DATE\6]
    SERIN2 PORTB.1, 188, 3000, RXERROR, [WAIT ("GPGGA"), skip 39, STR SAT\2, skip 1, STR HDOP\5\",", STR ALT\6\",", STR ALTU\1]
    There you go, there is plenty more after that but that is the bits that are giving me the first set of troubles.
    /*edit*/ it is laid out better than that, much the same as the example you gave
    Hmmm, very odd. That also compiles without error here.
    Just added these labels.
    RXERROR:
    INT:
    Do you have any more SERIN2's in the program?
    Are you trying to create a Variable, Constant or Label named STR anywhere in the program?
    Added: What version of PBP do you have?
    I have just tried compiling only that code from above with adding in the 2 extra labels and I get the same errors as before. I am using proton compiler 2.1.3 to do this.
    I have to admit I am more than a bit new at doing all this so would there be any settings I have may have overlooked when starting out?
    I know the code I have is meant to work on a 16F628 as I have seen the end result from a previous application
    Ah, there we go. Wrong language.
    The program you have is written for PicBasic Pro from meLabs
    The compiler you have is Proton+ from Crownhill Associates.
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  2. Getting SERIN2 to work?
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 20:10
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 02:38
  4. SERIN2 digit parsing
    Last Post: - 7th January 2007, 23:15
  5. Serin2 and STR Modifier
    By _Ian in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2005, 16:25
