ICSP from Picstart Plus?
Results 1 to 3 of 3
    Default ICSP from Picstart Plus?
    Hi all-
    I recently upgraded my Picstart with the flash board. I noticed that there are 5 pads on the upgrade piggyback board that are not allocated to anything. Would I be lucky enough to hope that these contacts could be led out to make an ICSP programmer out of the Picstart?
    Nop, those contact are the ICSP points to program that Flash Upgrade Board.
    I used it once when an update failed and put my PICSTART unusable.
    If one day it happen and you have a third party programmer who support the PIC on the flash upgrade module, send an e-mail to the Microchip TechSupport and they will send you the BOOTLOADER firmware. erase the PIC, then re-load the BOOTLOADER in. THEN replace the Module in the PICSTART and redo the firmware update.
    Quote Originally Posted by Microchip TechSupport ticket.. well part of
    Hello Steve,
    You will notice on the PUM PCB there is a 5pin through-hole section on the PCB that you can use for reflashing the device. Pin 1 on the PCB should correlate to MCLR/VPP, Pin 2 VDD, Pin 3 VSS, Pin4 PGD, and Pin 5 PGC.
    Maybe pin4 and 5 are reverted in that.. i had a problem when i flash it the first time and i revert those pins... My mistake or their.. i can't confirm since it worked BTW
    I use PicStart for ICSP... no problem as now. See the folowing thread
    http://www.picbasic.co.uk/forum/show...ht=simple+icsp
    Look post 19 and 25.
    Default Thanks for the warning
    Hi Steve-
    Yup, I should have thought of that, the flash in the Picstart had to be programmed at the beginning somehow !
    Thanks for the links and advice
    Angus Anderson
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 17:31
  2. ICSP from EPIC to Breadboard && 16f88
    By rdxbam in forum General
    Last Post: - 14th December 2008, 20:13
  3. Picstart plus and pic18f2331
    By jhasan in forum mel PIC BASIC
    Last Post: - 26th November 2008, 06:36
  4. what IS an ICSP connector?
    By mslaney in forum Schematics
    Last Post: - 5th March 2008, 07:05
  5. Replies: 1
    Last Post: - 10th December 2007, 23:57
