PFC8583 Connection and I2Cwrite I2cread!
Results 1 to 12 of 12
    Apr 2005
    Default ds1302 AND pfc8583
    pfc 8583 is counting 1 minute in 2 minute ?
    and second is counting to 99?
    Wink Help from Brazil
    Hi, I am a Brazilian Electronic Engineer and my website is www.fdai.net
    I would like to help my friends that have problems with PCF8583 and Melabs PICBasicPRO
    My code for this :
    ' PCF 8583 APREDENDO_1.0
    ' programa para testar o chip PCF8583
    ' na placa do Distribuidor de Energia
    ' 26/Fev/2006
    define OSC 20
    DEFINE ADC_BITS 10
    define ADC_CLOCK 1
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    symbol SCL = PORTC.3 ' I2C clock
    symbol SDA = PORTC.5 ' I2C data
    symbol UP = PORTA.4
    SYMBOL DOWN = PORTA.3
    SYMBOL ENTER = PORTA.2
    SYMBOL SEL = PORTA.1
    ; Configuração do PIC
    TRISA=%00111111
    TRISB=%00000000
    TRISC=%00100000
    TRISD=%00000000
    ADCON1 = $0E 'Configura somente RA0 como entrada de AD
    PORTB=%00000000
    PORTC=%00000000
    PORTD=%00000000
    ' VARIAVEIS DO PROGRAMA
    HOUR VAR BYTE
    MINUTE VAR BYTE
    DAY VAR BYTE
    MONTHY VAR BYTE
    YEAR VAR BYTE
    S VAR BYTE
    M VAR BYTE
    H VAR BYTE
    D var byte
    Mn var byte
    Y var byte
    TEMPO VAR WORD
    lcdout $fe,1 'limpa o display
    Pause 500
    lcdout "PCF8583 Aprender"
    Lcdout $fe,$c0
    LCDOUT "FDAI Eletronica"
    Pause 1500
    Pause 100
    I2CREAD SDA,SCL,%10100001,2,[S]
    I2CREAD SDA,SCL,%10100001,3,[M]
    I2CREAD SDA,SCL,%10100001,4,[H]
    I2CREAD SDA,SCL,%10100001,5,[D]
    I2CREAD SDA,SCL,%10100001,6,[Mn]
    I2CREAD SDA,SCL,%10100001,7,[Y]
    IF PORTA.1=0 THEN GOSUB ACERTAR
    lcdout $fe,1 'Limpa o LCD
    lcdout $fe,2 'cursor n primeira posição
    lcdout "Hora: ", hex(H),":", hex2(M),":", hex2(S)
    lcdout $fe,$c0 'segunda linha do display
    lcdout "Data: ", hex2(D),".", hex2(Mn),".20",hex2(Y)
    Pause 500
    goto Main 'VOLTA PARA O LOOP PRINCIPAL
    ' Rotina de ajuste do relogio RTC
    ACERTAR:
    lcdout $fe,1
    Lcdout "Acertar hora"
    Pause 1000
    TEMPO = 1000
    'Verifica se algum botao de ajuste foi pressionado:
    VER_BOTOES:
    IF TEMPO =0 THEN
    GOSUB GRAVAR_HORARIO
    tempo = tempo -1
    ' Checa se algum botao de ajuste de h/min foi pressionado
    If PORTA.3 = 0 Then decmin
    If PORTA.4 = 0 Then incmin ' Last 2 buttons set minute
    If PORTA.1 = 0 Then dechr
    If PORTA.2 = 0 Then inchr ' First 2 buttons set hour
    pause 50
    Goto VER_BOTOES
    ' Increment minutes
    incmin: minute = minute + 1
    If minute >= 60 Then
    minute = 0
    Endif
    Goto debounce
    ' Increment hours
    inchr: hour = hour + 1
    If hour >= 24 Then
    hour = 0
    Endif
    Goto debounce
    ' Decrement minutes
    decmin: minute = minute - 1
    minute = 59
    Endif
    Goto debounce
    ' Decrement hours
    dechr: hour = hour - 1
    If hour >= 24 Then
    hour = 23
    Endif
    goto debounce
    'essa é uma parte da rotina de acerto do relogio
    debounce: 'atualiza o relogio na tela na hora do acerto do relogio
    pause 200
    tempo= 90
    lcdout $fe,1
    Lcdout $fe,2
    Lcdout "Acerte Horario:"
    lcdout $fe,$c0
    Lcdout dec2 hour, ":", dec2 minute, ":00"
    goto VER_BOTOES
    GRAVAR_HORARIO:
    'Converte para Hexadecimal
    DAY = 26
    MONTHY = 4
    YEAR=06
    M = MINUTE/10*16 + MINUTE//10
    H= hour/10*16 + hour//10
    D= DAY/10*16 + DAY//10
    Mn= MONTHY/10*16 + MONTHY//10
    Y = YEAR/10*16 + YEAR//10
    I2cwrite SDA,SCL,%10100001,2,[0]
    I2Cwrite SDA,SCL,%10100001,3,[M]
    I2Cwrite SDA,SCL,%10100001,4,[H]
    I2CWRITE SDA,SCL,%10100001,5,[D]
    I2CWRITE SDA,SCL,%10100001,6,[Mn]
    I2CWRITE SDA,SCL,%10100001,7,[Y]
  1. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 14:01
