Servo control woes
Results 1 to 25 of 25
    Angry
    Eris's pulses are NOT 200 to 400 ms, as you tell,
    but 200 to 400 x 5µS !!! this EQUALS 1 to 2 ms ...
    read your manual more carefully before hoping to give lessons ...
    Straight back to primary school !!!
    Hope not to read you any more about that. CENSORED !!!
    E.O.F.
    Jan 2006
    Istanbul
    Cool Apology
    Acetronics,
    I would like to apologize for the things I said.
    You were right and I was wrong. I missed some parts and behaved impolite.
    I also sent you a private message to apologize.
    Sayzer
    Wink no public apologies needed ...
    [QUOTE=sayzer]Acetronics,
    Hi, Sayzer
    that's kind from you ,
    the only important thing is you've learnt something useful ... I don' like this teaching method ... but I'm pretty sure you will always remember about PULSOUT resolution.
    a good joke is my favourite method for students to keep things in mind.
    That's the only real important thing....; may be ... life respect too, but it's not the right place to discuss it here.
    Default Update: absolutely no progress
    I've tried all the tips you guys gave, and have also been trying any and all PicBasic servo control code I could find on the net, but something is still not right. I've tried four different servos that I know to be functional. I've tried a 16F690 and a 16F628A, with the internal oscillator and with an external 4MHz crystal. I've tried changing the pulsewidths and pauses to every reasonable and many unreasonable numbers. I've switched breadboards. I'm shopping around for a goat to sacrifice to the PIC.
    Here's what I'm trying to use now, with a 16F628a:
    trisb = 0
    cont var byte
    cont = 0
    led var PORTB.1
    hither:
    low led
    for cont = 0 to 50
    pulsout PORTB.0,110
    pause 18
    next cont
    goto yon
    yon:
    high led
    for cont = 0 to 50
    pulsout PORTB.0,190
    pause 18
    next cont
    goto hither
    It is a slightly modified version of some code from the rentron site, which was meant for a 16F84. My include file (not the whole thing of course) looks like:
    device pic16F628A, xt_osc, wdt_on, mclr_on, lvp_off, protect_off
    My LED does flash convincingly, but still my servo heads to one extreme and stays there. This is keeping me awake at night now. What mistakes might I still be making? Does anyone know of an example of a working servo controller written in PicBasic, including a circuit diagram and not intended for a 16F84? I just need something functional to build on.
    You're probably sick of this thread by now, but any help would be appreciated.
    Jan 2006
    Istanbul
    Cool
    Try this code.
    Schematic and code are also attached.
    @ DEVICE intrc_osc, MCLR_OFF,WDT_OFF,PROTECT_OFF
    DEFINE LCD_EREG PORTA
    ' Set LCD Enable port
    DEFINE LCD_EBIT 7
    ' Set LCD Enable bit
    TRISA=%00100000
    ' RA5=Input, Rest= Output
    TRISB=%01100001
    ' RB6, RB5, RB0 = Input, Rest=Output
    '--------Assign name to ports---------------
    potvar var portb.0
    'Pot is connected to RB0.
    servo var portb.3
    'Servo is connected to RB3.
    Button1 var portb.5
    'Button1 is connected to Portb.5 and increases the frequency.
    Button2 var portb.6
    'Button2 is connected to Portb.6 and decreases the frequency.
    '---------Variables-------------------------
    pulse var byte
    'Variable to hold Pot value for servo Position
    freq var byte
    'Variable to hold Button1 and Button2 adjustments for Frequency
    '--------Initial Setup----------------------
    Freq=18
    'Initial Frequency
    '--------Main Loop-------------------------
    loop:
    IF button1=0 then freq=freq+1
    'Incr freq
    IF button2=0 then freq=freq-1
    'Decr freq
    IF freq>30 then freq=30
    'Max. Low freq
    IF freq<5 then freq=5
    'Max. High Freq
    pot potvar,255,pulse
    'Read pot and store the value in pulse variable
    If pulse>240 then pulse=240
    'Max. Pulse 240mS
    IF pulse<60 then pulse=60
    'Min. Pulse 60mS.
    pulsout servo,pulse
    'pulsout the stored pot value (pulse) to servo pin.
    pause freq
    lcdout $fe,1,"Pulse:",#pulse
    LCDOUT $fe,$c0,"Freq:",#freq
    goto loop
    Question little walkaround ...
    Hi, Eris
    Seem strange ...
    There's one last thing we didn't had a look to : Your supply !!!
    Could you describe it or better send a scheme.
    On my side, I try your code on my 628 R/C testboard ... just to be sure!.
    Wink Walkaround highly requested ...
    Hi, Eris
    Bad news ... I copied and pasted your code, just changed portB N°s as required here ... put a 6LR1 cell ( there's a regulator on the board !!! ) and a futaba servo.
    Every thing goes as you programmed it : the led blinks and the windscreen wiper does its job ...
    The problem is not ( no more ... humour ) in your code ...
    So, What to do ??? ...
    First verify your servo supply ( good common ground w/Pic ... enough current to feed the servo ...)
    Second verify the signal lead of the servo ... servo behaviour smells no received signal !!!
    In that way I would recommend you !!! SOFORT !!! to add a 1k resistor between Portb.0 and your servo connector.
    I keep the line
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Replies: 10
    Last Post: - 26th May 2008, 08:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
  4. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
  5. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 00:34
