Servo control woes
Results 1 to 25 of 25
    Jan 2006
    Istanbul
    Cool
    Ok, Acetronics I agree . People make mistake even the ones with 30yrs of experiences.
    Could you pls tell us what happens if we send 250mS - 300mS pulse to an R/C servo at 50Hz?
    Also, 350mS and 400mS at the same freq?
    How would servo respond to these pulse(s) ?
    Pls do not make it so complicated so that we, the learners without 30 yrs of experiences, can learn something from your valuable words. Before you post your answer, make sure that your answer does not conflict with your previous posts;
    Angry Stoooooop !!!!
    Hi, sayzer
    So, you've decided to be frankly ridiculous ... your problem !!!
    250ms pulses @ 50 HZ gives .... a firm "1" ( or "0" ) level !!! you've just recreated the resettable monostable mutivibrator !!!
    Who should go back to primary school ??? ( period = 1 / frequency ... no need a highschool for that )
    your servo wil just have the little "jump" for amplifier settling at power up ... and won't move any more.
    you shouldn't have tried .... you're really boring.
    Jan 2006
    Istanbul
    Cool
    Finally you got it Acetronics,
    That is what I have been saying.
    If you look at the original loop, below, the code is sending pulses from 200mS to 400mS. In this case, the R/C servo would goto extreme edge and stop there at its max input pulse (let say 240mS). However, the code keeps sending larger pulses upto 400mS even though the R/C servo already stopped at 240mS.
    -----Orginal code-----
    loop:
    for i = 200 to 400 'When i=240, servo stops, but loop keeps increasing the pulse.
    low servo
    pulsout servo,i
    pause 18
    next i
    goto loop
    An engineer like you, age 49, should be in teaching mode rather then an egoistic mode. You should be using more explicit words to express your knowledge and have others understand what you are trying to say rather then using complicated engineering terms (an expression of egoistic unsatisfactory career to show others how much you know and others don’t)
    I will stop here. This is going nowhere.
    Let stop here Acetronics; it has no benefit to any of us.
    Angry
    Eris's pulses are NOT 200 to 400 ms, as you tell,
    but 200 to 400 x 5µS !!! this EQUALS 1 to 2 ms ...
    read your manual more carefully before hoping to give lessons ...
    Straight back to primary school !!!
    Hope not to read you any more about that. CENSORED !!!
    E.O.F.
    Jan 2006
    Istanbul
    Cool Apology
    Acetronics,
    I would like to apologize for the things I said.
    You were right and I was wrong. I missed some parts and behaved impolite.
    I also sent you a private message to apologize.
    Sayzer
    Wink no public apologies needed ...
    [QUOTE=sayzer]Acetronics,
    Hi, Sayzer
    that's kind from you ,
    the only important thing is you've learnt something useful ... I don' like this teaching method ... but I'm pretty sure you will always remember about PULSOUT resolution.
    a good joke is my favourite method for students to keep things in mind.
    That's the only real important thing....; may be ... life respect too, but it's not the right place to discuss it here.
    Default Update: absolutely no progress
    I've tried all the tips you guys gave, and have also been trying any and all PicBasic servo control code I could find on the net, but something is still not right. I've tried four different servos that I know to be functional. I've tried a 16F690 and a 16F628A, with the internal oscillator and with an external 4MHz crystal. I've tried changing the pulsewidths and pauses to every reasonable and many unreasonable numbers. I've switched breadboards. I'm shopping around for a goat to sacrifice to the PIC.
    Here's what I'm trying to use now, with a 16F628a:
    trisb = 0
    cont var byte
    cont = 0
    led var PORTB.1
    hither:
    low led
    for cont = 0 to 50
    pulsout PORTB.0,110
    pause 18
    next cont
    goto yon
    yon:
    high led
    for cont = 0 to 50
    pulsout PORTB.0,190
    pause 18
    next cont
    goto hither
    It is a slightly modified version of some code from the rentron site, which was meant for a 16F84. My include file (not the whole thing of course) looks like:
    device pic16F628A, xt_osc, wdt_on, mclr_on, lvp_off, protect_off
    My LED does flash convincingly, but still my servo heads to one extreme and stays there. This is keeping me awake at night now. What mistakes might I still be making? Does anyone know of an example of a working servo controller written in PicBasic, including a circuit diagram and not intended for a 16F84? I just need something functional to build on.
    You're probably sick of this thread by now, but any help would be appreciated.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Replies: 10
    Last Post: - 26th May 2008, 08:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
  4. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
  5. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 00:34
